kevins build up
Post by Silverbullet » Thu Nov 29, 2012 4:44 pm
Hmm those headlights look interesting, replaceable bulbs? Any more info on these? :)
Brumby Kid
Post by Brumby Kid » Thu Nov 29, 2012 8:51 pm
I'm about to do a write up of how to replace MY headlights.
There's a bit to it but its all narva stuff.
Cheers Cam
Dads Car: 02 Impreza WRX STi
Post by El_Freddo » Thu Nov 29, 2012 9:08 pm
Silverbullet wrote:Hmm those headlights look interesting, replaceable bulbs? Any more info on these? :)
As BK has said - it'd be a kit or replacement light housing. I had the same on my torana - new housing that was semi sealed. Saved me a fortune on blowing old headlights!
Before looking at Kevin's images I thought it was the quad lights - in which case you can find factory sets that are semi sealed on other 80's vehicles that also have the quad lights. They're pretty much a standard size but do double check if you're going down this route!
The only issue with semi sealed is when you get water in them, muddy water especially!
And Kevin: Ooh! Shiny!!!
84superoo
Post by 84superoo » Fri Nov 30, 2012 9:59 am
These are just stranded size 7x5" rectangle headlights that are semi sealed with H4 90/100w globes that I bought separately, the headlights just bolt in no cutting or anything and are the same as Hilux, Hiace, Navara, Triton, Courier, Early Supra, TF Rodeo, Gemini, MK Patrol and heaps more I bought my dad the round version for his GQ Patrol with 130w globes and there unreal.
Post by Silverbullet » Fri Nov 30, 2012 4:28 pm
Excellent; common, plentiful and impressive performance that's what I like to hear :) With these now powerful lights I assume you can still adjust them properly so you don't blind other drivers?
Another thing to add to my list :p
Post by TOONGA » Sat Dec 01, 2012 8:54 am
http://www.ebay.com.au/itm/400316326285 ... 1423.l2649
ad says they are for the mighty boy but they are the same lights as the MY series, ebay search for 7x6 or 200mm x 142mm semi sealed headlights.
84superoo
Post by 84superoo » Sat Dec 01, 2012 10:16 am
Silverbullet wrote:Excellent; common, plentiful and impressive performance that's what I like to hear :) With these now powerful lights I assume you can still adjust them properly so you don't blind other drivers?
Yeah mate they are still fully adjustable;).
84superoo
Post by 84superoo » Fri Jan 11, 2013 8:22 am
testing my image uploading:confused:
84superoo
Post by 84superoo » Fri Jan 11, 2013 8:23 am
i did it!!!!!:D
84superoo
Post by 84superoo » Fri Jan 11, 2013 5:31 pm
if any one is interested in a 1993 GQ patrol i've got one for sale, it will parse roadworthy with a change of steering wheel as it had one a year ago and hasent even done 1000ks since, and its just come back from bendigo dyno tune where it got a tune and some new parts. starter was replaced not long ago, has a couple of upgrades.
Post by El_Freddo » Fri Jan 11, 2013 10:16 pm
84superoo wrote:testing my image uploading:confused:
Well done mate! We've got the Sandpit for testing things like this out ;)
I forgot that you were in benders, I'll have to keep an eye out for you when I'm down that way. You might see Ruby Scoo around from time to time...
84superoo
Post by 84superoo » Sat Jun 29, 2013 5:18 pm
hey everyone its been a long time since I've done an update because I've been so busy, I've spent the whole day today fibre glassing around my windscreen ready for my new windscreen to go in. ill take some pictures soon and let them do the talking. I took Kevin for his second RWC test and they gave me another list of things to do so I was pretty bummed about that but I have almost finished every thing that's needed and ill try again probably in about 2 weeks :rolleyes:
84superoo
Post by 84superoo » Sat Jun 29, 2013 5:38 pm
also replaced my clutch with an exedy heavy duty clutch, I bought a clutch that apparently would fit my car but it was 25mm to small, which means my car takes the same size clutch as an l series so in a way its a good thing because it means I have a bigger more heavy duty clutch. so I ended up havening to buy 2 clutches. if anyone wants a brand new 200mm clutch you can come get it for $50 or swap for something.
84superoo
Post by 84superoo » Wed Jul 17, 2013 11:29 am
New windscreen has gone in along with a new rubber, so now it doesn't leak every time it rains. I don't know why but I've decided to go the opposite direction with Kevin I'm no longer lifting it, I'm lowering it, front and rear bars are off and I just bought some 14x8 rims, Kevin's going JDM! :roll:
Post by El_Freddo » Sat Jul 20, 2013 11:06 am
Going to look for a front air dam and side skirt kit?
You'd fit in to the Bender's cruising scene in a lowered subi rather than a lifted subi ;)
Got any pics of your progress/where the vehicle's at?
84superoo
Post by 84superoo » Wed Jul 24, 2013 8:49 am
El_Freddo wrote:Going to look for a front air dam and side skirt kit?
I'd love to get a front spoiler for it but I cant see myself finding one! :(
The reason I'm going this way with it now is because all my mates have lowered cars and would have been the only one with a 4wd.
I will try and post up some pictures soon :D
Post by El_Freddo » Wed Jul 24, 2013 9:03 pm
84superoo wrote:all my mates have lowered cars and would have been the only one with a 4wd.
Well, I was the only one in my group with a 4wd... Now there's two of us! Gotta start the bug somewhere ;)
Your wagon should look sick lowered if you do it right ;)
84superoo
Post by 84superoo » Thu Jul 25, 2013 8:18 pm
Here's where kevins at at the moment.
Post by El_Freddo » Tue Jul 30, 2013 7:48 pm
Where's the like button?!
Looking great mate! I hope it's been turning heads!
84superoo
Post by 84superoo » Thu Aug 15, 2013 9:21 am
Kevin had been registered exactly one week and I hit a tree on a rainy day in the bush :(
