Brumby build with a difference
rotary in a brumby has been done, ive seen it done, and went like a shower of shit. hope to see another one day
and neil,,,,its brap brap brap,,,,,LOL
rak rak rak is too similar to the dak dak dak of a subaru lmao
davo
davo
heheheniterida wrote:I was referring to making it RWD - but yes I did think that comment was a bit silly when I wrote it
What about your rotary forum mates? have they got any pics or info on fitting one??
And the problem is what??seagull wrote:needs full throttle every were
hahaha! (and this is generally what the population actually believe!)niterida wrote:Good thing it only does 200ks between rebuilds then
-97 Landcruiser
						-97 Landcruiser
Well its not looking good. The Rotor is 465mm long once you include the gearbox adapter and remove the PS and Air Cond pumps, AND run an Electric Water Pump to get rid of bulky inlets and outlets. I have 500mm from the gearbox to the radiator support panel so that only leaves 35mm to mount a radiator
I calculated that at most I could move the gearbox back 25-30mm so I could possibly squeeze a radiator in but would then need to mount the fans in front. But then where would I put the Front Mount Intercooler ??
Also the crossmember isn't really being cooperative and would need major reworking to move the motor back another 50mm. As it is the engine mounts are going to be a pain in the butt without making it more difficult moving the engine back.
Now the Subie motor is only 410mm long including all the front pulleys, leaving a good 90mm for a radiator and fans - which is still a bit tight though. Of course that means I don't have to modify the crossmember or make custom engine mounts etc.
So given my limited fabrication skills I would have to say that the rotary idea is just a bridge too far
Of course the fact that I have just bought myself a Liberty RS Turbo wagon has swayed the decision too. I can put all my good bits on the wagon - DCCD gearbox, Brembos, 18's, coilovers, swaybars etc and I still have an EJ22 / 5 speed, 16's, 4 pots etc to go in the Brumby and then maybe in the future when funds are available I can upgrade to STi motor etc for the Brumby. AT least doing it this way keeps the cost and the build time way down.
						- Brumby Kid
Bugger, was looking forward to seeing a rotary in a brumby, are you really going to do a twin engine brumby like your signature?
Please correct me if I'm wrong. Differences between STi and non STi.
6 speed gearbox
Brakes
Turbo
Water cooled inter cooler
Tuned differently.
Cheers Cam
6 speed gearbox
Brakes
Turbo
Tuned differently.
Cheers Cam
Thats the long term plan - got a rusty Brumby shell sitting waiting but it will be 2 NA motors not turbosBrumby Kid wrote:Bugger, was looking forward to seeing a rotary in a brumby, are you really going to do a twin engine brumby like your signature?
Cheers Cam
Gotta build ths Brumby first, then make a trailer out of the smashed Brumby and then make a car trailer out of a big pile of steel I have left over from my old business and I am still trying to buy a rusty hatchback Torana from around the corner............
Check back in about 10yrs
						I have made a small breakthrough
Bolted all the suspension and crossmembers on to the chassis rails and placed the body over the chassis. Now everything looks like it is in the right place until I put a wheel and front guard on only to discover everything is at least 50mm too far forward !!
So I need to move the engine crossmember mounting points back by 50mm on the chassis and I may be able to squeeze the rotor in after all
But that also means I need a new floor because the WRX one I was going to use is now going to be 50mm too short at the front
