Silverbullets' resto: Engine, gearbox, suspension
Re: Silverbullets' resto: Engine, gearbox, suspension
Sounds like an awesome trip! I’ll check out your video.
I didn’t realise you were yet to do some rocky climbs. I’ll get Ruby Scoo back to offroad (and onroad) fit and then we should meet up for some touring of some choice areas in vic. The Pyrenees are probably the closest to you with the best steep and long climbs.
Everything look ok post trip under the vehicle?
- Silverbullet
Pyrenees looks nice! Looks like Wooded native forest, not enough of that here in SA to explore.
Todays drama; broke the clutch cable! Was just creeping into the driveway at work this morning when it let go, bunny-hopped into my parking spot and stalled it
Very lucky it was just the very end that came off, under the dash. The cable actually broke just inside the crimped ferrule giving me enough to silver solder a new end on. Lucky it happened at work where I had the facilities to silver solder and not out bush in a couple weeks time
I'm heading north out to Marree to pick up a pleasure flight over Lake Eyre which is over 8 hours drive. Haven't decided yet but I will probably wind my way back through the Flinders ranges over the week. Don't plan on doing any serious 4WD'ing by myself in a strange surround but will still try to see as much as I can. Pics to follow!
Well done on the repair! Looks neat.
The scenic flight should be good. Best get cracking, I hear Lake Eyre is evaporating quickly! Probably why southern NSW and northern Vic seem to be getting good rain while southern vic isn’t getting its usual amount.
Either way, the whole trip will be an awesome experience! Have a safe trip there and back when the time comes.
Holy banana!Silverbullet wrote: ↑Sun Sep 28, 2025 10:34 amThis weekends project had some urgency, going on a 4WD club trip next weekend. Only noticed 2 weeks ago when I stuck my head under there that the moustache bar was bent like a wet noodleYesterday I started before 9AM, got the car back together after 6PM so it was a big day and I am very sore today
Went to Subareck Pauls place last week (2 hour drive one way) to get a couple of moustache bars to weld together, and some Brumby torsion bars.
As to how/when the old bar bent I don't know for sure. I suspect it is due to the rear locker binding up sometimes on sealed roads. Every so often navigating a low(ish) speed, RH turn of ~90 degrees the rear end emits an enormous "BANG" followed by another bad noise that keeps going until I stop, then move off again. Has done it from day one, completely random, getting less frequent as time has passed.
Apologies for the vertical photos!
- Silverbullet
3d printed bushings
This has been on my to-do list for a while, although my desperate bodge job fix from months ago had held up surprisingly well. There's a rod for the L series 5 spd shifter linkange that has bushings in each end. My bushings were in multiple pieces and earlier this year I managed to buy 4 new genuine Subaru rubber pieces, ordered in from Japan
Only for them to completely dissolve in my hands turning into rubbery muck when I went to install them
I took dimensions and drew up some new bushings back then in hopes of sending them off to be custom made. That never happened but recently a mate with a new 3D printer said he could print them out of flexible urethane. I got him to print the rubber piece from urethane and also the thin plastic casing that goes inside the rubber piece. They came out bloody good and fit together perfectly first try. Just installed them in the car today and they fit perfectly in the steel housing, the crush tube fits perfectly down the middle of the bushings, very happy with the results for a first attempt
The car is all back together so now we begin the durability/drivability test. Let's see if they hold up and if they introduce any new noises into the cabin. Although I think the urethane can't be any stiffer than the fossilized original rubber bushings.
The black plastic parts were printed separately and pushed into the urethane parts very easily by hand.
Installed into the shifter rod, couldn't be happer with the fit up
The stuff it was replacing, and rubber rings I made during the last bodge-job fix
All back together, let's see if it holds!
That’s neat mate! I didn’t know the 3D printers could print urethane - I’ll have to look into this!
Bantum made some on thingiverse ages ago. I printed some in my early days (about 9 months ago
) but never fitted them. The piece of Subarino’s garden hose I fitted back in 2016 is still doing the job - there’s a trick to selecting second though…
I’m looking forward to how these work out for you
- Silverbullet
FYI the 3d printed bushes are holding up fine so far. Also got a brand new L series clutch cable made. Gave the Cypriat OEM part to Flexible drive here in Adelaide to be extended. They only re-used the metal ends of the outer sheath, everything else is new. They even used PTFE coated inner cable like the original, inside a PTFE sheath which I'm happy about.
Also dragged out my old Singer sewing machine to make some infill-shade panels for when I've got the tailgate up. More than a few times when I'm out camping I've found the late afternoon/evening sun comes through these triangular gaps on the side of the tailgate, and lands right onto my fridge or battery pack, or water storage and makes it all roasting hot. I used tent fabric thats silver on one side and sewed some strong magnets into the edges for quick up/down when required.
These are version 1.0, there will be improvements made in version 1.1
That’s a simple and awesome addition Silverbullet!
I can see the design “getting out of hand” - v2… like the Ute swag or the SS torana hatchback tent
Keep us posted how it goes. I hope the magnets are strong enough for a decent bit of wind when necessary.
- Silverbullet
New dyno tune
To those who don't know, I'm moving to Mount Gambier! Starting a new job next week, the day after Easter long weekend. Why? Well in the news today, average Adelaide house prices have overtaken Melbourne. So I say, get f#@%ed!
Anyway, I decided I needed to get my cars tune looked at since I've noticed it pinging on the hills coming back along the SE freeway (they're steeper on the way back to Adelaide than they are outbound) Plus many other little annoying things, the idle control being total dog shit, couldn't go anywhere near WOT without pinging etc. And with many trips back and forth coming up (most towing a trailer too) I needed the car to be running right.
Glad I did it, somehow they found an extra 10 kW!
and 17 N/m of torque. Got the idle to behave correctly with the IACV plugged in (has been un-plugged forever, last tuner couldn't get it to work) and I can mash WOT with confidence, even up the steepest hill with the A/C on. I think overall the engine temps are staying lower too. Apparently the intake air temperature correction was turned off! Which would explain why it felt extra gutless on those stinking hot Adelaide summer days. Also great to know it hasn't lost any performance in the 2 years (!) since the engine swap, there's no damage to the engine. Interested to see if the fuel economy is better or worse
I reckon you’ll see better fuel economy. Anytime you can gain more torque it’s for the better. And having the temp correction in play that will make a huge difference.
How did the original tuner get it so wrong? You’re lucky you didn’t kill your engine.
I’m looking forward to hearing about your fuel economy and better drivability.
All the best with the big move. Not a good time with the price of fuel though!
- Silverbullet
Well, drove down here to Mount Gambier on Easter Monday and, didn't notice a difference in fuel economy (doesn't drink any extra, phew)El_Freddo wrote: ↑Thu Apr 02, 2026 7:52 pmI reckon you’ll see better fuel economy. Anytime you can gain more torque it’s for the better. And having the temp correction in play that will make a huge difference.
The extra torque definitely helped on the freeway and highways. Had a trio of jackass Jeeps in front of me at one point playing silly buggers with each other and ignoring the traffic chaos behind them
Original tuner? well, I think maybe inexperience did it. I remember him having difficulty troubleshooting and said that he's not a Subaru expert. Then the older bloke Subaru expert of the shop said "it's just an engine"
Time for a dash cam so you can report these dickheads.Silverbullet wrote: ↑Thu Apr 09, 2026 9:56 pmHad a trio of jackass Jeeps in front of me at one point playing silly buggers with each other and ignoring the traffic chaos behind themSo next overtaking lane I may or may not have gotten over 140 km/h to get past them all
Not before one of them pulled into the overtaking lane right in front of me at 90 km/h for no particular reason
Noice!
Jeeps, say no more…
Jeeps, say no more…
- Silverbullet
So I got into a spot of bother this weekend just passed, at our clubs annual sand driving/training weekend at Peake
This is why sometimes you should walk a big dune/climb before you drive it! Some other cars had attempted this one and failed, as well as a 4.5 ton Mitsubishi Canter camping truck. Guess I didn't fully expect to make it either and just went for it without knowing what was on the other side. Surprise I got up easily on the first try. At the top when all you can see is sky it's hard to know where to point the front wheels. I just kept them straight and powered over the top to not get high centered. The track went slightly left, so I ended up sliding off to the right and down the hill almost into the bushes. Hard to tell how steep it is in the pics, and the sand was so deep and soft it was hard to even walk in
If I was alone I wouldn't tackle something like this. Someone in our group came in from elsewhere and winched me out in a few minutes. Don't think I could have self recovered from this, I was precariously close to going over the edge into the bushes
Good fun though, a great weekend away!
So the proverbial s**t was trumps, the moment you went over the top of the dune and saw the track bend left.
Not a nice feeling.
Not a nice feeling.
Looks like a wicked weekend out!
Glad no harm was done to the wagon, a bruised ego will recover, if it was bruised in the first place.
Was this the only highlight of the weekend?
- Silverbullet
No egos were harmed in the making of this weekend
It is billed as a training weekend in our club calendar anyway. I think the more experienced members who were doing the training were glad for a real life opportunity to demonstrate some of the techniques they talked about earlier. That is, bridle strap to spread the winch strain, soft shackle versus D shackle, winch dampers, communication etc.
I have on board footage from my car of some various parts of the weekend. Only problem is I don't have any PC hardware capable of importing and editing the footage with me at the moment. Less than 2 weeks now until I move into my new house though
I'll upload the footage one day.
