MY Wagon Rust repairs
Yer I'm hearing you.
Bunnings and Gasweld are pretty close together and are both close to me about 3km by road and I pass them on my way to and from work.
Wanted to do some blasting on the other side of the wagon today but didn't happen because I wanted to get a white guard from B3 but discovered it was rusted out.
I have a red guard origunaly from B1 which is dinted so painted it saturn white from a pressure pack, rough yer I know but the rest of the car is faded so who cares, I just didn't like patchwork pannels.
Sunny looks pretty neat Bennie
Trivia quiz.
How many pressure packs does it take to paint the external surface of a front Brumby/wagon guard.
Trivia quiz.
- Brumby Kid
How many coats? For one coat to paint the front 1/4 panel it should use less than Hal a can I reckon.revmax wrote: Trivia quiz.
I desperately need an air compressor and a gun, getting sick of pressure pack cans.
Cam
- Silverbullet
Nah it must take more than that, I used up 1.5 cans of primer covering up where my old stripes used to be...I'd say little over 2 cans for the guard? I'm just going to bite the bullet and save up for a paint shop to do itBrumby Kid wrote:How many coats? For one coat to paint the front 1/4 panel it should use less than Hal a can I reckon.
Cam
I used 3/4 of a can but that was all I had, some spots were a little darker so i recon you could get away with 1 can with tree coats. If it was white on white or Beige, one can would be heaps.
still plugging away.
should have most done by end of tomorrow except the worst bit, which is the drivers side rear. I blased it on the weekend and it looks like swis cheese.
I am going to have to cut a chunk out and either rebuild it or cut a piece from another wagon and weld it in.
out with the grinder and some fresh metal.
- IMG_1418.jpg (71.72 KiB) Viewed 5760 times
- IMG_1416.jpg (36.27 KiB) Viewed 5760 times
- Silverbullet
in front of the rear wheel drivers side.
- IMG_1419.jpg (37.32 KiB) Viewed 5758 times
from the other day.
before blasting
after blasting
plate welded over and painted.
before blasting
after blasting
- IMG_1411.jpg (38.98 KiB) Viewed 5398 times
- IMG_1410.jpg (37.39 KiB) Viewed 5399 times
- IMG_1382.JPG (90.58 KiB) Viewed 5398 times
found me camera.
from the outside
still to weld a piece on the inside
from the outside
- IMG_1430.jpg (101.63 KiB) Viewed 5388 times
- IMG_1432.jpg (97.05 KiB) Viewed 5390 times
yer. I have welded the inside in but it was tricky to line up.
Once lined up it was point, pull the trigger, weave then stop for a few seconds, then start the cycle again. Got it in and it is structualy sound but the high spots had to be ground off the welds.
Have made a template and cut the sheet for the channell support and may get a chance tomorrow to weld and bend it into shape.
