lifting an Exiga
adrian_ACT
lifting an Exiga
Post by adrian_ACT » Mon Sep 06, 2010 6:46 am
I am after a 6-7 seater & we like the Exiga - unfortunately there is no 'Outback' equivelant.
Is it easy to lift an exiga by 25 mm, and who can do this in the SYD - CBR region?
SUBYDAZZ
Post by SUBYDAZZ » Mon Sep 06, 2010 8:04 am
It shouldn't be much different to any other Subaru model, but it's a matter of if someone has designed and manufactured a lift kit to fit such a new model.
SUBYDAZZ
spike
Post by spike » Mon Sep 06, 2010 8:29 am
couple of questions
Whats a exiga?? The new tribeca??
How high are you looking to lift it??
Pm me and maybe we can work somthing out to lift it an inch or two but it wont wont be engineered
Post by Alex » Mon Sep 06, 2010 10:09 am
not much info on the exiga here, seeing as though its a new model, id say youd be one of the first to lift one.
shoudlnt be too difficult id imagine.
spike the exiga is basically a 7 seater liberty wagon. Just abit larger.
78sti
Post by 78sti » Mon Sep 06, 2010 10:29 am
Should be able to use outback struts front and rear and outback (or similar) spacers on the rear subframe to achieve the same height as the outback.
spike
Post by spike » Mon Sep 06, 2010 3:24 pm
try the outback or we can probably do a strut lift
Post by Gannon » Mon Sep 06, 2010 7:16 pm
Shouldnt be a hassle to lift it as they use the same suspension setup from a Gen3/ Gen4 wagon (multi link rear suspension, not like the mcpherson rear strut of the Gen1 and Gen 2)
Post by AlpineRaven » Mon Sep 06, 2010 9:18 pm
I'm pretty sure you can lift it.. its like you can lift forester, WRX, Liberty & outback etc etc then you should be able to do that as well!
SUBYDAZZ
Post by SUBYDAZZ » Wed Sep 08, 2010 5:03 pm
SUBYDAZZ
