Since arriving a couple of weeks ago, I have;
Lightened the interior by 20kg of Dust and Sand from everywhere.... Mostly under the seats and inside dash. It was crusty and glued in to every crevice.
Removed a Hanky jammed in the Fan Blower
Fixed oil pump and pressure switch oil gushing leak (prev owner swears it didn't leak oil ha ha).
Repaired fan blower resistor (all speeds work now!)
Adjusted idle mixture (anti tamper plug was still in the idle mixture screw!)
Next I'll tighten up gearshift z bolt and whatever annoys me next
![Smile :)](./images/smilies/icon_smile.gif)
I've got this really weird cold start exhaust smoke that is very light blue and thick. Bit disappears as soon as warmed up. I haven't lost a drop of coolant and the plugs don't seem oily. Oil is clean as a whistle. Also. I could run high vacuum on down hill no throttle for 3 km and I don't get smoke when I jump on the throttle again. I thought that exhaust valve guides would allow oil to get sucked into cylinders if it was valve seals/guides. I'll start another thread if I can't find what's up.
Thanks for reading.
