L series speakers
Get wild & funky with your Mobile disco ...
waggaclint
L series speakers
Post by waggaclint » Fri Dec 29, 2006 3:19 pm
just wondering whats the biggest speakers you can fit in the front doors of a lseries behind the door trim that is cheers clint........
2011 Forester X
Post by Subafury » Fri Dec 29, 2006 7:43 pm
if u mean behind the plastic grill then id say about 4 inch which is i think wat the factory ones are.
but if u cut it out u can fit 6" ones like i did.
also did u know there is a speaker under the dash where those holes are? i found it interesting
Chris_Rogers
Post by Chris_Rogers » Fri Dec 29, 2006 9:36 pm
6.5" and you can still keep the OEM covers. you will need a bit of MDF to space it out and a bit of body filler to seal the gaps.
Audio Express
1987 HR31 Nissan skyline
1990 R32 Nissan Skyline GTS4
subanator
Post by subanator » Sat Dec 30, 2006 12:25 am
And another tip is rewire them, factory Subi wiring has a common negitive for each left front and rear; and same again for right side. I spliced into cables from the door wiring into the plugs found under the carpet around the door pillars back to the unit. Mine were 4", and looks possible to go bigger as suggested.
Post by Gannon » Sat Dec 30, 2006 8:07 am
That centre speaker was only in the DL's i think, because of the mono radio.
Gl's had a stereo radio/tape and didnt have the centre speaker
waggaclint
Post by waggaclint » Sat Dec 30, 2006 10:52 am
yeah had a look this morning i fitted up some 6.5 speakers they went in pretty easy just spaced em out a bit so the window reg wouldnt hit em....cheers guys...
2011 Forester X
clarky
Post by clarky » Sun Jan 13, 2008 7:04 pm
where would u guys mount a subwoofer in a l series, where it wouldnt take up much space
adamb
Post by adamb » Sun Jan 13, 2008 7:08 pm
I put 2 8" subs in the cargo box under the carpet at the back. it works quite well, just need to find a way to secure the lid as it vibrates too much.
clarky
Post by clarky » Sun Jan 13, 2008 8:11 pm
did u have to mount the box or was the box realy slim
adamb
Post by adamb » Sun Jan 13, 2008 9:07 pm
the box is really thin, just enough to house the 2 subs in depth and width. i think its just out of its tuning frequency cos of the box being a bit on the small side, but still sounds alright.
Chris_Rogers
Post by Chris_Rogers » Mon Jan 14, 2008 11:59 am
pioneer or earthquake make shallow subs. from there remake the door into a bit of solid MDF and seal the area below and you are done.
Audio Express
enduro
Post by enduro » Sat Apr 05, 2008 10:12 pm
waggaclint wrote:just wondering whats the biggest speakers you can fit in the front doors of a lseries behind the door trim that is cheers clint........
mine OE speakers were 5 1/4"
2001 Outback 2.5i man.
[ex-owner]1991 L-Series
Kappage
Post by Kappage » Sun May 04, 2008 8:16 pm
Out of curiosity if you put two 8" subs in their where does your spare tyre go?
daveosubi
Post by daveosubi » Mon May 05, 2008 12:54 pm
clarky wrote:where would u guys mount a subwoofer in a l series, where it wouldnt take up much space
I think Bluesteel's did a great job of his, I wish I had tried out the fiberglass for mine.
here's a pic of what he posted in my thread
This is what I did, and it took a while.
box w/out front
The best bit is I can still fit a mini bike in there and use most of the space with the seats down.
Suby Roo
Post by Suby Roo » Mon May 05, 2008 1:09 pm
Kappage wrote:Out of curiosity if you put two 8" subs in their where does your spare tyre go?
In a L series the spare tyre is under the Bonnet, So there is plenty of room in the bit in the boot.
Return to “Sound / Entertainment Systems”
