Bantum's Infotainment System
- Bantum
Software ...
Yep - Will def. get some anti glare screen protectors. As I'm new to all the Android stuff, so don't really know much about it or what I'm doing - just playing with it to see what it can do really. Add : Found the bit to enlarge the text so Ok with that ...
The initial idea was to link a head unit ( for power sound system ) with the tablet ( via HDMI ), then be able to hook up a mobile phone ( hands free ) to the tablet ( via Bluetooth ). Later I can also look at linking it all up with a plug in device for OBD II ( as seen earlier in the thread ). P.S. the tablet device already has radio on it, just needs a antenna ( ear phone jack ) & good to go ...
To me its just finding / making stuff that works, weather that's practical or not is another matter. I'm also looking to hook up a USB storage device ( 1Tb HD ) with enough room on it to load up some music + down load a DJ system to run it. So just a matter of finding the right software I guess.
Note : I've loaded 'Nokia PC Suite' on my desktop which works fine on windows, just need to find an equivalent for Android ( if there is such a thing ) ... Not to worry if I can't get it to work on the tablet, no real biggy as I was looking to get a new phone eventually, just have to make sure its compatible I guess ... :/
Thanks for your help ...
Cheers, Bantum ...
Cheers, Bantum ...
- Bantum
OBD II Readers ...
Did a bit more digging and found out the ECU I have is possibly for an EA82T, with case codes of : 22611 AA400 + A11-000 R14 ( will post some photos later )
Might be able to jerry rig something up to get readouts from various functions like speed, rpm, temperatures + a few others. Only thing is to find a pin out diagram to suit + a matching OBD II Bluetooth reader of some sort ( posted one earlier in this thread ) so the tablet can pick up the signals.
Any body got any recommendations for compatible solutions ?
Ciao, Bantum ...
Ciao, Bantum ...
- Bantum
Sound Box ...
Also been busy with some concept sketching :
Not 100 % sure this will work yet, as I'll have to wait until I've got all the bits together & see what fits ... ( main one missing is the subwoofer )
Does anyone have an old one lying around their not using ? - Looking for the shallow depth type, with approx. 1000 W, somewhere between 12" to 20" dia. ...
Even something that I can beg / borrow / steal ? ( for test fitting purpose only )
Ciao, Bantum ...
Ciao, Bantum ...
- Proton mouse
- Bantum
Woofered ...
Ok - Thanks to Proton Mouse, I have a sub woofer to tryout :
One of the other problems to sort is the Seat Belt :
I'm also after another Amp similar to one I already have ( Boss ) to suit the Door & Cabin Speakers next ...
Add : Do note most of this equipment is only temporary until I can afford the high end stuff ...
Nearly there ...
Ciao, Bantum ...
Nearly there ...
Ciao, Bantum ...
- Silverbullet
- Bantum
Subbed ...
Ok tried fitting some of the bits that I've manage to gather & see if it would work :
Seems to fit with seat all the way back, so will keep working on it.
Looking to make a up a box later when I'm happy with the arrangement :
Note : Big thanks to Proton Mouse for the loaner, P.S. - you can pick it back up whenever you in city next ...
Cheers, Bantum ...
Cheers, Bantum ...
- Bantum
Storage ...
Sorry I forgot to take a photo with them in place ( they just fit if I put the Amp horizontal ) Don't normally take them out, just crack them open ...El_Freddo wrote:So where will you store your roof glass when they're out or don't you do that ?
Ha - way off from completion yet, still got the doors to do ...El_Freddo wrote:Looks good though - I'm sure that will solve all squeaks and rattles
Side affect from this test fitting - I may have to change the planned orientation of Amps & keep the 6x9's in existing location ...
Decisions, decisions - will sleep on it 'till I come up with another plan ...
Ciao, Bantum ...
- Bantum
Skinned ...
Also played around a bit with the door panels to see what needed to be done :
Keep on truckin' ...
Ciao, Bantum ...
Ciao, Bantum ...
- Bantum
EL Wire ...
Got some new fangled tech to try out :
Not sure where it's going yet, still need to workout how to put it to good use ...
Cheers, Bantum ...
Cheers, Bantum ...
- Bantum
Head Unit ...
Saw this the other day, just might be what I need to complete the system :
More details here : http://www.aliexpress.com/item/2-Din-Ca ... 50809.html
Ticks most of the boxes :
Small & compact, Bluetooth, GPS, Mobile Phone, Wi-Fi, 4 Channel Subwoofer Output ...
Also has a Radio & Equaliser :
Supposedly even has OBDII ... ?
Will have save up for it though @ $250 ...
Ciao, Bantum ...
Ciao, Bantum ...
- Bantum
Swiped ...
Thanks Bennie,
I'm not sure about that aspect - It doesn't say anything about security on the page, but I could make it removable I suppose ...
It does have a camera, so could link it up with some sort of tracker and take candid snaps ...
Making small amounts of progress, but it's still taking forever to get anything done on it though ...
Cheers, Bantum ...
Cheers, Bantum ...
- Bantum
Woofer ...
Found this :
Found here : https://www.elite-electronics.com.au/In ... Y.facebook
It's a shallow type Subwoofer, and should give me a bit more room to fit , just need to decide if its worth $120 ...
Cheers, Bantum ...
Cheers, Bantum ...
- Bantum
Update ...
Got another bit of the puzzle sorted : 10" Boss BA1090 Subwoofer ...
Working on some drawings to put it all together now ...
Ciao, Bantum ...
Ciao, Bantum ...
