Aux input mod - Instructables
- Thalass
I don't know if this has been mentioned before (I'll delete it if it has - man my memory has been bad lately) but I found this on instructables a month or so ago, and it works!
My solder job on the 3.5mm jack is a bit dodgy, but it does work well. I would like to figure out how to commandeer the cd stacker button rather than use the switch - but I'd need to work out a latching circuit that trips off when another button is pushed. And I'd have to disassemble the head unit even more... I smoked a track doing this as it is, so I ended up tinning the right sized wires and inserting them into the right sockets in the plug (after I repaired the pcb track) . Should have done that to start with.
Anyway, here's the link. http://www.instructables.com/id/Add_an_ ... ad_Unit_I/
Nice one dude... never knew that could be done.
Thanks a lot
Dave
Thanks a lot
Dave
- vincentvega
Any chance u want to share how this is done with a Pioneer unit?
Dave
Dave
- vincentvega
- Captain Obvious
subarino, some depending on how old it is pioneer units you can change the aux out to and aux in, pretty sure i can with mine!
http://www.instructables.com/id/E6855TRSX0EP28793D/
With the Pioneer one... it's a bit of a worry the amount of times he suggests you could blow up your Ipod. But very interesting... thanks.
Dave
Dave
- Captain Obvious
dont know what the go is there, if i remember i will dig out the manual and scan it so you can see if you can change you aux output to an input if you want.?
bryan
bryan
