I phone connector
I phone connector
My son has just bought an 04 Liberty and has the Macintosh PF-25511 stereo. Does any body know which socket is the aux and if there an adaptor cable available for an Iphone 5 and does it charge the phone at the same time.
Hi and Welcome bug i
I'm no expert on these stereos but being the factory units were made long before the iPhone 5 was released, then I doubt it would. I know there is no AUX input and the only way the play external music is via FM transmittor like this one...
http://www.megabuy.com.au/belkin-caraud ... 10046.html
I did this to my Gen3 Outback to get an aux input
How to add an AUX input to your factory Gen3 Headunit
I actually have a few spares that I made up, you you will have to check if yours actually has the 13 pin round connector, which from memory, I doubt it does.
There are interfaces that you can plug your iphone into and connect to the CD stacker port on the back and you can actually control your playlist from the head unit, but you need all your songs arranged into 6 playlists
This might do the trick Car Interface iPod iPhone input Adapter for SUZUKI with Clarion OEM radio
Hey Gannon, They do have a 13 pin plug but it's square, would these work in the same way as the round?
Here's a pic of the rear of the PF-25511
- PF-25511.jpg (57.23 KiB) Viewed 31921 times
Yeh I think thats the correct unit. Spoke to the guy at the car stereo shop today. He traced down the original kit- AE1251 no longer available but you may be able to pick one up on ebay. He did also say the Suzuki use the same unit. Looks like the right connector only problem I can see is he has the Iphone 5 I'll look into it deeper.Gannon wrote: This might do the trick Car Interface iPod iPhone input Adapter for SUZUKI with Clarion OEM radio
Mick.
Yeah the iPhone 5 uses the small connection now, so I think BT is the best way.
The square "CeNET" plug is used for the CD stacker control and by looking at the pin-out, it does have analogue audio, but the problem is that it wont work without some kind of digital signal, and the ea1251 somehow emulated it.
The other way is to get a stacker and install it, put a random disc in it and then splice into the cable and tap the audio lines. That way the stacker will produce the digital signal, but your ipod will supply the music
If you have some time up your sleeve, have a read of this, it may provide an answer http://forum.liberty.asn.au/The USB/Aux-in/ipod compatibility superthread
Apple sell an iphone5/new ipod converter for $30 but you should be able to get them on Ebay by now, Handy for my new phone in the brumby and it can control and charge my iphone 5. keen to know how you go in the outback though as i'm shopping for one now!
87 targa brumby (Neglected),
+ others.
+ others.
Could you install a later model headunit from a Gen 4 that has the aux in capability?
