Ebay aluminium radiator for MY Touring wagon with A/C
Put your take on things that go into Subies here ...
henpecked
Post by henpecked » Wed Dec 31, 2014 11:04 pm
http://www.ebay.com.au/itm/311183517034 ... 1439.l2649
well made unit that was essentially a simple slip in. Shipped quickly and all was fine.
write up here
http://www.ausubaru.com.au/showthread.php?t=25574
henpecked
Post by henpecked » Sun Mar 22, 2015 11:00 am
Progress report.
It worked absolutely fine in all conditions, no leaks - all good.
Actually works even better with the air con turned on in hot weather, as the air con fan stays on and even when 35+ outside that fan on its own, seems to keep below the temp required for the thermo-controled fan to cut in.
pezimm
Post by pezimm » Sun Mar 22, 2015 8:40 pm
^That's pretty good! I noticed the same with the aircon when I changed the radiator in the Foz.
Still thinking about the fan cut-off/always on mod for the radiator fan...
hallpearl
Post by hallpearl » Fri Mar 27, 2015 12:24 pm
wow i cant believe you radiator lasted for 30years! Incredible! lol mine lasted for 19 years and it look worst.
henpecked
Post by henpecked » Fri Mar 27, 2015 12:39 pm
hallpearl wrote:wow i cant believe you radiator lasted for 30years! Incredible! lol mine lasted for 19 years and it look worst.
I wasn't the original owner, and I have no idea if this was the original radiator in the auto wagon.. The one in the brumby isn't as the car is a manual, and the radiator is for an auto.
Return to “Product Reviews”
