Carpet
- FROG
Carpet
Anyone here bought a moulded car carpet for their Subie
Ive been quoted $136.50 landed at my door from ALLCARCARPETS
Any thoughts on quality and fit??
cheers Andy
cheers Andy
Hey Andy,FROG wrote:Anyone here bought a moulded car carpet for their Subie
cheers Andy
I have fitted a ALLCARPETS carpet. Not to a subie , it went in to a charger. It almost went straight in . A cut here and cut there just to make it fit better to that car. Back then , when i fitted it , a few years ago now, they weren't as good as today's carpet , but was still nice. Looked the goods.
Now that i think about it , it may have been a TRUE FIT CARPET.
rtcb65
Redneck Rick.
Redneck Rick.
- Backyard_Brumby
- FROG
Rang Truefit and after a while I was told no suitability on the Lrtcb65 wrote:Hey Andy,
Rang Allcarpets direct and got offered 120 plus 16.50 freight to my door , which I thought was pretty good .
I bought a maroon Charger in Brisbane in 1989
- FROG
They are hard to judge, you may have to cut the rear end off maybeBackyard_Brumby wrote:just took delivery for a moulded carpet from allcarcarpets...looks the goods so far, quality seems good however have not yet fit it up to the brumby....It looks a little big (more like the wagons) but then again my eyes could be deceiving me
What did you pay if you don't mind telling?
- Silverbullet
Seen a few around for sale on the net, was thinking about one for the M.Y. When you fit one do you have to put adhesive of some sort down first? I thought it might be tricky getting all the holes (for seat bolts and seatbelt latches etc) lined up properly so it sits flat and smooth.
I just fitted a Trufit moulded carpet in my Brumby. It was around $180 for front and back plus standard underfelt. I could have got a slightly cheaper one but they were out of stock so I paid a little extra for a better quality one.
The fit is good. It was difficult to cut out all the holes and the bits around the shift levers and handbrake. It came with no cut outs at all so it was in and out a million times while I cut little bits off here and there. The holes for seats and seatbelts were the worst as there is no real room for error. I cut it so I could just get the bolts through but this made it really hard to line up.
There was a bit extra on the sides and back and I trimmed the minimum amount off and just tucked it under the trim. I didn't use any glue or anything, just let the trim hold it in place. I did stick some underfelt to the inside of the plastic panel under the rear window hoping it will reduce some noise.
David
David
- FROG
Charging
Just found some real old photos circa 1989 NT to WA
