test your oil on a test medium product
Put your take on things that go into Subies here ...
Post by steptoe » Thu Jan 21, 2010 8:24 am
I have not tried it yet, but thought I'd share a find with you. May come in handy in buying a used car.
It is called engine checkup, sells six test pads for about $30 details at proquip.com.au
Looks like it sells in a yellow cardboard box counter display with a flat sheet of six test pads to drop warm oil drip of dipstick onto to test for state of oil, engine efficiency (yeah? "10.8l per 100km" :) ), presence of contaminants, water, fuel or anti freeze and the degree of each
shortcut to car inspections -
If you know of and have tried it maybe give a write up in here
Post by RSR 555 » Thu Jan 21, 2010 10:08 am
Never heard of it before but it sounds like a great idea and I can't see why it woundn't work. We have special testing tablets to check for water in A1 Jet Fuel and they work a treat.
heres a link to the PDF page but I too would like to know if anyone else has used them?
http://www.proquip.com.au/ProductPages/ ... e/ECUP.pdf
GOD
Post by GOD » Wed Jan 27, 2010 9:24 am
Put a drop of oil onto a bit of white paper/cardboard and use your finely calibrated eyeball. Shows a fair bit. Without looking at that kit, I suspect it would be little more than bits of paper, and a guide to interpreting the results.
Dane.
Subyroo
Post by Subyroo » Wed Jan 27, 2010 5:03 pm
RSR 555 wrote:Never heard of it before but it sounds like a great idea and I can't see why it wouldn't work. We have special testing tablets to check for water in A1 Jet Fuel and they work a treat.
Has the paste been superseded RSR 555?
The QF engineers in Townsville used to use paste smeared onto a metal tab that was attached to the lid and reached the bottom of the jar and they sampled each tank on the aircraft before departure.
Peter
Post by AlpineRaven » Wed Jan 27, 2010 10:09 pm
Ive heard of this but never bothered... Anyone have?
Post by RSR 555 » Wed Jan 27, 2010 11:08 pm
Subyroo wrote:Has the paste been superseded RSR 555?
Not sure how they do it on-shore, my mate who works at Perth Airport can maybe tell me next time I see him. Off-shore US rig we use is...
http://www.pdfdownload.org/pdf2html/pdf ... images=yes
Sorry for going off the topic but I'm still interested in anyone that has used one of the oil kits :) btw GOD, I'm going to try what you said, sounds good if you know what you're looking for :cool:
Post by El_Freddo » Thu Feb 18, 2010 4:47 pm
While over in perth in 07 I picked up a bottle of coolant that was Australian made, can't remember what it was called now. The thing about it was that it was a coolant that did everything it should. It was green but if it changed colour it would indicate several things - blow head gasket, oil in the coolant etc - it had a colour for every usual problem you could have with coolant.
I never really got to test it for a blown head gasket, can't remember if I dropped the coolant or blew up the radiator... Either way we don't get it on this side of the burnt country :( I'd be keen to give it another go.
As for this product, I'm really not sure if there's a quick solution to working out the condition of a motor - prior experience and a through checkout is usually the best method in my book.
Return to “Product Reviews”
