Outback OEM suspension
- MINIMOKE
Hi there,
I have just found this forum....good to see. I'm based in Perth and have been subscribing to a USA forum, which seems to be very region specific, especially as they seem to have different builds/models over there.
Having just upgraded my 2.5 Gen3 Outback to a 2.5 Gen4 I have a question regarding Outback suspension.
The Gen2 was the Limited edition with "self-levelling" suspension. I didn't take much notice of this until now when I realise how good it was compared to the suspension on the Gen4.
I need to stop the back end sagging when the car is fully loaded or towing and I want to explore some options.
How difficult/expensive is it to install the OEM/optioned "self-levelling" suspension? BTW, does anyone know how this works? From my experience it seems to do a good job
What other options are there to me bearing in mind that 80% of my driving will be two-up so I don't particularly want to make the rear suspension any harder/higher than normal.
Dave
Dave
I wouldnt have a clue about "self leveling" suspensions, but only one thing I can tell you from what I've seen caravan people with Foresters and Outbacks (including Liberty) have raised suspensions in rears to enable heavy towing without sagging and while they have a load they tell me it was like standard suspension height without load on and I can see it myself. I can understand you wouldn't like to see the rears higher than normal and it would effect the headlights as well.
- Ruperts Trooper
The self-levelling rear suspension on current Outbacks is self-energising - it doesn't use an external compressor so is different to earlier versions.
The rear damper (shock absorber) includes a small hydraulic pump which pressurises a hydraulic chamber which extends the damper to lift the car. At a certain length of damper a tiny bleed hole is opened which releases the pressure - thus keeping the height stable. It takes around 2km of use to get up to height.
It should be possible to buy the self-levelling dampers from your Subaru dealer and fit them as a direct replacement.
Get in touch with FROG on here and see what he can quote for you. he works in Subaru Spare parts
______________________________
my last 4wd that i built and had fun scaring subarus on fire trails:twisted:
full NSW rego. 270liters diesel. 140liters of water. airide suspension on front axle.
self contained for a week with 6 adults. Island cab was cut and narrowed 300mm to fit the chassis.
Great fun off road. Now lives in FIJI as a mobile dentists truck.
- FROG
wayyy exxxie look for second hand
- masterjohnson
what's with this "self-leveling suspension"? does all impreza models have this already? just curious. not really interested in having this. no money for buying subaru oem partsfredsub wrote:Aren't the "lifted" (vs std) King springs, really designed to increase load handling, so that maybe all you need?;)
still yeah wonder what subaru sell the optioned "self-levelling" suspension as parts ? won't be cheap, how expensive is the question
- bobbyjimmy
