Brumby 5 Stud conversion - Suspension options
Posted: Sat Sep 27, 2014 10:19 pm
Well I'm looling to achieve better handling out of the little ute. Its currently RWD amd has the adjustable suspension wound all the way down. Ive replaced most of the bushes, mounts and bearing under the car. Feels tight except for the steering and brakes!
Cr***B*** don't make their kits anymore however I got my hands on a pair of L-Series modified control arms that'll accept an EJ ball joint. So i can slap in the ej hub, bearing, 4 pot brakes and a shock.
I'm not sure what shock to run? What springs? I was thinking GC8 KYB's with lowered king springs? ?
I want something low but not so it hita curbs and the likes!
The rear I was gonna get the stock hubs redrilled... ive seen some ridiculous prices on custom hubs and the works... I can get some bolt on spacers that I'd probably be comfortablr with but redrilling seems like my only decent option. I have a new pair of monroe shocks in the rear which work well and are firm. I find the torsion bar provides good adjustment for height and dampening of the shocks.
Ive got these light 16inch sti wheels to go on!
I'll go with a set of toyo teo plus tyres in 205/50r16 (24"). These should give me good grip and shouldn't rub.
while the suspension is apart I'm going to swap the steering rack to a Forester 3.2 turn (lock to lock) verse the brumby 5.5 turn! It won't be power steering but should work well until the ej207, awd and dccd go in..
While she does contain rust its only in the tray (only half a tray exists) and both front guards. This is easily fixed with some new panels and a new tray.
what are peoples thoughts?
The vehicle
The vehicle
