Radius rod bushes
Radius rod bushes
I had grand intentions of replacing bushes in the front end of my L series while i had the whole front end apart doing the suspension so I bought a few different ones. Turns out I didnt need the control arm bushes or lower swaybar bushes i bought as they were very tight so I didnt bother. Upper swaybar and radius rod definitely needed doing.
I couldnt for the life of me get the nut on the radius rod undone on the first one I tried, and I started to round the edges of the nut so I abandoned it right there. Does anyone have any tips or experience with this? When a ring spanner starts to round a nut you know your in trouble..
At the moment those bushes make a nice big squelching squeaking kind of noise all the time so Im keen to get them changed out.
- Bantum
I'd clean the exposed threads up as much as possible, spray with a penetrative lubricant and let it soak for few days. Then get a pair of vice grips and use them to loosen it.
If that doesn't work get a nut splitter ( you will need to replace the nut anyway ) Finally - clean up the thread with a die ...
Cheers, Bantum ...
Cheers, Bantum ...
I'd go with what bantum has said with penetrate and clean the threads as much as possible. I also use a spanner that only has 6 sides, as these reduce the chances of rounding out bolts and nuts. I just replaced mine in the yellow MY wagon and found what a difference to the handling. I used the red nolathane ones.
believe it or not, Bunnings isnt too bad on price for sockets! Any auto or tool place will have em. I think its Sidchrome or poss Kinchrome have special non-slip sockets that have little grooves in the face to help grip rounded nuts. Brilliant idea but I think they only come in sets
