Addco Swaybars fro the US
- Rodeo4jake
Addco Swaybars from the US
G'day guys, here's something else for my future wish list. Checked out whiteline Swaybars & they no longer make the rear bar for mys, at least that's what the bloke I spoke to said. So searching on USMB saw that some guys on there mention Addco ones. After research found they make a 1 inch front, part #717, & 3/4 inch rear, part#353. Prices are $179, & $122 plus freight, which seems like it wouldn't be that much. Found more than 1 place that would ship them here.
1 site had a PDF of the install instructions & it confirmed for me that they should fit Aussie cars.
Cheers Jake
Cheers Jake
- Silverbullet
The MY's could benefit from a bigger sway bar I reckon, rear one as well maybe or at least mine would (body roll nearly throws me out of my seat sometimes) But do they still fit and work if you lift the vehicle?
- Rodeo4jake
I haven't fitted a lift kit before, but if the standard ones work when lifted the bigger ones should too.Silverbullet wrote:The MY's could benefit from a bigger sway bar I reckon, rear one as well maybe or at least mine would (body roll nearly throws me out of my seat sometimes) But do they still fit and work if you lift the vehicle?
As for the rear, it should still work cos it only bolts to suspension components. So it would just move down from the body of the car with the rest of the rear end.
I have fitted rear Swaybars to 2 leaf sprung cars before & the improvement to turn in response in cornering was very good.
- Rodeo4jake
- Rodeo4jake
- Silverbullet
- Rodeo4jake
- Rodeo4jake
Here it is! All the way from Delaware Ohio.
Well it's all fitted to the car now. Went on fairly easily. Had to drill out a couple holes a bit bigger & trim some brackets. Will post some pics of it on there tomorrow. Overall I'm pleased with the product though. Just gotta take it for a fang down the nearest twisty road to feel the difference now.
Cheers Jake
Cheers Jake
- Rodeo4jake
Here's some more photos
The link ends bolt up to a bracket that mounts to the bottom shocker bolt.
The hole for the shocker bolt was too small, so I drilled it our to the required size. Also, when bolted up, these brackets touched the driveshaft boot. So I trimmed the edge off them on the grinder.
Here's a shot of the link end
One shot of the Brumby in front of the shed
I've taken it for a quick spin now. You can tell the difference, turn in response is much better. Even just on lower speed turns like roundabouts. If you like your cars to handle nice I think it's a worthwhile addition.
Wow I didnt realise it would be that different to the L series rear bar.
At one stage I was gonna fit an RX rear bar to an MY sedan, but never got around to it, it looks like it wouldnt have fit anyway.
Looks good and I have no doubt it makes a difference to the handling, but that hub attachment looks very close to the CV boot.
- Rodeo4jake
I just went on the JEGS site, shipping to AU is now $244.20 (economy option) ! Probably with UPS instead of USPS...crazy price.
Excellent write up.
Slightly off topic, but still on sway bars, wasn't there something written on the forum some time ago regarding front sway bars for MY's being different diameters depending on year/Brumby or wagon/model.
I cant recall now but I thought one bar was considerably bigger is diameter than others so if this can be defined it may be worth sourcing these standard, larger bars if new ones cant be found.
I have sent JEGS an email to ask about the higher freight charge, and the possibility of a group buy.
Looking at those pics Jake, I reckon the sway bar was meant to be mounted above the K frame, not below it like you have - this explains why the sway bar has that forward point/bend in it - to go around the height adjustment bolt on the K frame.
I wouldn't mind one of these on Redback - but it's a cost thing, it's meant to be a budget build/cruiser Although this would be one step in the right direction for the setup of a WRX swap later Again, I'll probably never get there with this one though...
Update from JEGS is they now only offer FedEx priority, as opposed to FedEx economy freight. And no volume discount either. So Rockauto / Summit / eBay is probably the way to go for those looking to purchase. If there are other members looking to buy in the short-medium term PM me and we can amortise the freight...
