Suspensionlift
Posted: Wed Aug 29, 2012 5:31 pm
by Wesvo
Where can I get the suspension lift from in Melbourne?
For a subaru Brat
Posted: Wed Aug 29, 2012 5:55 pm
by stilson
Try crossbread performance.
[url]http://www.*********performance.com/contact[/url]
Posted: Wed Aug 29, 2012 5:59 pm
by TOONGA
without the "A" in it :)
by Wesvo
stilson wrote:Try crossbread performance.
Thanks stilson
Posted: Wed Aug 29, 2012 6:01 pm
by Wesvo
The website has body lift kit,
I need the suspension 2"lift
Thanks
David
Posted: Wed Aug 29, 2012 7:06 pm
Wesvo wrote:The website has body lift kit,
David, I'd be going for the body lift. These older subarus need the body lift to keep the CVs happy in the long term. If you go for a 2 inch suspension lift only you'll chew through CVs faster than you can think about.
Unless you've got the body lift blocks already it's not worth looking for the strut lift only. Even then this won't work on the rear as it's a torsion bar setup - there's a bolt in the centre of the setup that you can wind up or down to change the rear's stance. Some level it out, I like a bit of lift in mine... if I had one.
Posted: Wed Aug 29, 2012 7:39 pm
by Wesvo
El_Freddo wrote:David, I'd be going for the body lift. These older subarus need the body lift to keep the CVs happy in the long term. If you go for a 2 inch suspension lift only you'll chew through CVs faster than you can think about.
Thanks for the info, I need that body lift but also the suspension lift that's the problem
Thanks Bennie
Posted: Wed Aug 29, 2012 8:09 pm
Wesvo wrote:Thanks for the info, I need that body lift but also the suspension lift that's the problem
No problem there... In the subaru world a body lift includes the struts as well - there's no chassis to just raise the body from ;)
Posted: Wed Aug 29, 2012 8:33 pm
by Wesvo
El_Freddo wrote:No problem there... In the subaru world a body lift includes the struts as well - there's no chassis to just raise the body from ;)
It says the struts are not avaible for them!
I would lift 2inch suspension!
Thanks David
Thank you Bennie
