3 Bolt Adjustment for negative wheel camber
Posted: Wed Nov 23, 2011 2:30 pm
Guys,
Can some pleas enlighten me on this 3 bolt adjustment to adjust the negative camber on an L. cause i've got some wild camber and wouldn't mind adjusting it.
Angus
Posted: Wed Nov 23, 2011 2:52 pm
by RSR 555
Are you talking about the rear? if so then it's just case of loosening them off and then retighten.
Posted: Wed Nov 23, 2011 3:07 pm
by Alex
RSR 555 wrote:Are you talking about the rear? if so then it's just case of loosening them off and then retighten.
while the back wheels are off the ground.
worked really well on my wagon.
Posted: Wed Nov 23, 2011 3:20 pm
yes talking about the rear.
Where abouts are these three bolts located? or will i know when i see them?
Posted: Wed Nov 23, 2011 4:12 pm
by Alex
from memory youll have to remove the wheel. Just behind it youll see them. Three pretty big bolts in a sort of triangle pattern. Pretty sure theyll have either a 17 or 19mm head.
you shouldnt miss them.
They can be bloody tight, so maybe give them a spray with wd40 now and let it soak in abit before you attempt to undo them.
Id do them up again moderately/very tight.
Posted: Wed Nov 23, 2011 6:22 pm
by NachaLuva
& maybe use some antiseize on the bolts so next time they're easy to undo...
