liberty control arm bushes
Hey guys,
i need to replace the big bush in my front drivers side control arm. Its the rear bush of the control arm (if that makes sense)
Has anyone replaced them before? Do they need to be pressed out?
The stock unit is oil filled, is it worth upgrading to a nolathane solid bush?
I believe all libs use the same part
Just buy a set of whiteline anti-lift mounts..
http://www.carmodsaustralia.com.au/whit ... rm-kca319a
- FROG
Bushings
Please elaborate H-top I'm interested as to whyH-top wrote:I don't rate nolathane anything.
I used the nolathane red bushes to replace
mine ( 92 liberty ) and I found the nvh went
through the roof ( quite literally
The whiteline ones are very nice
I alway$ thought the oil filled Subaru items were well thought out and clever for their day
- FROG
Pretty easy from memory I think we did it in an hour - two of us at lunchtime and I think we still had time for a pieAlex wrote:frog do you remember how hard the install was?
- FROG
H-top wrote:I've dealt with alot of nolathane bushes and
a concerning amount of them are fatigued and
cracked/split in short amounts of time.
Jobs that are almost warranty issues.
I rate superpro, great product. Also superpro
make whiteline's bushes, or atleast used to.
Just my opinion,
S
Sam
Do you think it's the quality of the material used or are the superpro ones made from a different .....athane ?
Lol perhaps
it may Be just a different Temperature at forming
or a small chemical change.
Either way i've seen loads with excess fatigue
at shorter Intervals than acceptable under non
performance use.
I would not use it if I could avoid it.
But sometimes it comes down to price
and in some cases they beat genuine.
I rate superpro.
performance use.
I rate superpro.
- bobbyjimmy
Access to a hoist and a press? Get the Whiteline Caster bushes #KCA375.
Access to a hoist only? Get a Whiteline ALK #KCA361.
Don't have either? Get whatever you want and pay someone to put them on - the nut that holds the bush and bracket on the rear of the control arm is that effing tight, without a hoist you can't get a decent breaker bar to it.
- Suby Wan Kenobi
Are these what you are after?
www.ebay.com.au/Control Arm - Lower Inner Front
www.ebay.com.au/Control Arm - Lower Inner Rear
Im soon gonna buy new bushes all round for my Outback, but i can only find fronts. The bushes for Gen3 multi-link rear suspension are not available in Australia (that i can find)
They are available in the UK, but wont post overseas
ended up ordering a set of these.RSR 555 wrote:Just buy a set of whiteline anti-lift mounts..
got them wayyy cheaper than the listed price, its great having mates in the parts industry!
Try http://www.powerflex.co.uk/products/Leg ... 622/1.htmlThe bushes for Gen3 multi-link rear suspension are not available in Australia
I have used there rear diff bushes (nothing available is aus for gen3) and they seem very good. Took about 1 week to deliver from the uk.
Are you going to divulge this price? or keep us in suspenseAlex wrote:ended up ordering a set of these.
dunno....i might beat around the bush for a while..RSR 555 wrote:Are you going to divulge this price? or keep us in suspense
side note...have you ever installed these paul? its easy ay?
Yes.. I have installed lots of them and info for info is a fair swapAlex wrote:dunno....i might beat around the bush for a while..
