Rounded Nut on L series
- [email protected]
hey guys,
putting my two inch lift in L series car and have realised that some of the nuts are rounded.
anyone got any ideas as to how to get them off?
cheers,
Angus
cheers,
Angus
use nut splitter. or cut them off with cold chisel. cold chisel is pretty quick.
"UNDERSTEER" is when you hit the fence with the front of the car.
"OVERSTEER" is when you hit the fence with the rear of the car.
"HORSEPOWER" is how fast you hit the fence.
"TORQUE" is how far you take the fence with you.
If it works, pull it apart to see why.- RSR 555
First to try would be a 6 sided socket followed by knocking on a smaller socket (cheap one and usually an imperial size), then a pair of vice-grips and lastly a cold chisel
