Bent Gen1 Lib rear suspension
Posted: Sun Mar 21, 2010 2:38 pm
by Gannon
My brother owns a 91 GX wagon and he was driving too fast on a dirt road and slid sideways into a bank.
The rear wheel now has serious positive camber and a little bit of toe in. We pulled the tyre off and the hub expecting to find a bent control arm, but they look straight.
He took it to a mechanic and they couldnt find what it was so they suggested that they will cut and extend one of the control arms.
This to me sounds a little dodgy.
What else could it be? A bent strut or maybe even the undercarriage
Any input is welcome
Posted: Sun Mar 21, 2010 4:24 pm
by daza
Take it to a Panel Shop and get a quote.
The quote should say what they're planning to do, eg change suspension parts or straighten chassis.
Daza.
Posted: Sun Mar 21, 2010 8:22 pm
by AlpineRaven
Could be something else... panel shop has all these points to point measurements... I would take Daza's advice.
Other option is to swap parts over see what happens.
Posted: Tue Mar 23, 2010 12:56 pm
by Suby Wan Kenobi
Not a bent strut? or the crossmember at the rear hasnt pulled out?
Posted: Tue Mar 23, 2010 1:26 pm
by Alex
sounds like a bent strut. They can be bent and youll hardly even notice by looking at it.
dont extend the control arm..sounds ludacris!
Posted: Tue Mar 23, 2010 3:20 pm
by Gannon
Thanks. Everything else looks straight so i was thinking the strut (even though i cant see any damage or mishaping.
I'll tell him to pick up a spare and try it out
Posted: Thu Mar 25, 2010 1:56 pm
by Suby Wan Kenobi
Unbolt the strut at the base and check it with a straight edge for a bend. If nothing else looks wrong it could be the strut.
Posted: Thu Mar 25, 2010 3:13 pm
by Gannon
Swapped struts, no difference.
I got a better description of what the mechanic was planning on doing.
He was gonna move one of the mounts (im assuming one of the lower control arm mounts)
I rekon his best bet is to get an adjustable lower control arm
Posted: Thu Mar 25, 2010 7:14 pm
by AlpineRaven
mate is it lifted or non lifted? or Outback struts?
