Handling issue L series IRS?
Post by steptoe » Fri Oct 23, 2009 9:01 am
My L Series sedan has a handling issue I think is related to the rear independent suspension, or my 14 inch rims tyre combo or the two together. It has not happened withe tyre rim combo on my Brumby with its different to L Series suspension.
I know the inner bushes for the rear arms are shagged due to the rust colour appearing around them
What happens is driving along at 80 to 100kph and shift lanes I get a sideways wallow or shift feeling come from the whole car but suspect it is the rear causing this. It is more a wallow back to the left lane almost to the effect it looks like I am side swiping car on my left!!
The only other cough * 'car' cough , I have experienced this in before was a Triumph 2500 between gear shifts in auto. These also had a IRS .
Foot to floor for the induction roar, shift up and got a sideways kick in the bum. Owner never chased this handling difficiency - think or hope it was crushed
Any experiences or suggestions other than replace bushes and see?
brumbyrunner
Post by brumbyrunner » Fri Oct 23, 2009 12:53 pm
Naturally if you've got worn out components then you should replace them. Email or pm Jeff from Crossbred Performance and he'll be able to set you up with new bushes that you can fit yourself.
Once you've checked that all the bushes haven't got any freeplay, your struts/shocks are all good and none of your rims and tyres are bent or out-of-round, you can start looking at this handling change. It sounds like a toe change or wheel misalignment problem so fix all the easy stuff first.
Settlement Creek Racing
Post by El_Freddo » Sat Oct 24, 2009 7:49 am
I can tell you that it will be those rear bushes - Baz (84 L series) doesn't have any on him anymore and around bends at speed he feels like one wheel "rolls" partly under the back of the subi as he crabs around the corner! If you're not ready for it the effect can scare the shit outta you...
Baz was retired last weekend too :(
Post by steptoe » Sat Oct 24, 2009 11:19 am
Thinking as much. I can spare the time and readies for them but not much more at the moment. Still tossing up the swap bits into my Brumby - think I gotta start what I finished and reduce my stable fees :) That's is what I was after, some experience.
Post by Gannon » Sun Oct 25, 2009 7:21 am
Could it be your tyres?
I just got new tyres (Bridgestone ER592) and they have a softer sidewall than what i had on there before, and the car feels like it sways a bit more in sharp cornering
Post by steptoe » Sun Oct 25, 2009 9:00 am
tyres have been on Brumby before, but not in the combo I have at the moment. It corners well it is just the lane shift thing. Tyres are old. I hate it when you buy new tyres and they feel worse than the old set and give you that feel you have now :(
