tires
- twilightprotege
tires
has anyone used 235/75/15 tyres on their L? (basically a 29" tire)
just curious as to the width if it'd cause any problems? any experiences on the sand with them?
The biggest tyred Ls I can think of:
showthread.php?t=11670
showthread.php?t=11179
http://ausubaru.com/forum/showthread.php?t=13992&page=6
And AndrewT and Fatz, but they've done stacks of custom work to make things fit.
Dane.
Dane.
- red_rocket
- twilightprotege
there's 2 reasons i'm going with 15" wheels - 1 because i already have a set, and 2 because they are far more common than 14" wheels and thus give me more choice for less $$$
and yeah, will be doing some "body" work to make sure they fit w/o rubbing.
was more looking for a "this is how they go on the beach" type replies. i dont know if it's just me, but i think 215 is on the touch thin side for really soft sand - or am i wrong?
- twilightprotege
You don't need wide tyres for the beach. Tyre contact area is a function of inflation pressure and vehicle mass, so a skinny tyre at 15psi will float above the sand just as well as a wide tyre at 15psi (all other things being equal), but without pushing as large a frontal area.
BTW, 215mm is 8.5", which about a million Ls are using.
Dane.
Dane.
- twilightprotege
you can fit the 29s on an L with 3" lift but you have to cut a fair bit out of the guards and have really good suspension. Alex managed this with his old WankyWagon. It did look a tad unbalanced, wheels too big for car. But it certainly worked really well offroad.
- twilightprotege
- red_rocket
Andrew,AndrewT wrote:you can fit the 29s on an L with 3" lift but you have to cut a fair bit out of the guards and have really good suspension. Alex managed this with his old WankyWagon. It did look a tad unbalanced, wheels too big for car. But it certainly worked really well offroad.
was that on a 15" rim?
and if so would 29's fit nicely on a 14" rim with a 4"lift(with minor, if any body work?)
otherwise i would just stick to 27's also
cheers
- twilightprotege
- red_rocket
- Mr Top Hat
- phillatdarwin
red rocket
have a look at this site very good to find a tire size some one posted it up some time back .
http://www.exploroz.com/Vehicle/Tyres/SizeCalc.aspx
it will convert all tire sizes
no can't get 29's on 14s. wouldnt make any difference anyway, the tyres are still 29" outer diameter regardless of the wheel diameter.
If you want to see Mr Top Hat's ones search for pics of Wanky Wagon (alex's old car). towards it's end it had those ones on it.
- red_rocket
