2 inch lifted brumby need HELP
- the gumbi brumby
Nealy 12 months ago i got a 2 inch ausubaru liftkit
finally got around to fitment
and cant get 4wd leaver to bolt back down and steering knuckle hits its self but not a problem
also difficulty going in to reverse
thanks chris
thanks chris
E10 BLEND KILLS CARBY CARS AND RUSTS STEEL TANKS
Had the same problem with my lift kit install re the gear levers.
Check the second last pic in this thread
showthread.php?t=13478
I just "massages" the transmission tunnel with a big hammer to get the 4wd lever to fit and work smoothly.
With the gear levr I managed to fix the problem of reverse by adjusting and tightening a bolt on the transmission lever.
Eventually I will remove the gear lever and cut it and weld it to a better shape.
Subaruby
Subaruby
Suspension lift.
Suspension lift.
- the gumbi brumby
You can just neatly modify the gear lever and the 4WD selector shaft, if you can get a hold of an oxy or welder. It's amazing what you can make fit with a 9Lbs hammer.
[SIGPIC][/SIGPIC]88 Subaru Brumby (Currently being restored.
84 brumby 2 inch Lift(very rough, Big tires)
Landrover series two. 186 holden banger under hood.
- the gumbi brumby
