Trailing arm bushes? _ 86 Lseries
Anyone know where I can source both inner and outer rear trailing arm bushes for my trusty old wagon? Intersate is fine can get them posted. Cheers, Pete
						I can Supply Nolathane brand ones. In Super Heavy Duty or Heavy Duty.
Sen me a PM if you are intrested.....
http://www.subiparts.com.au
0438 887 746
0438 887 746
- FROG
can supply the inners ie the ones that go to crossmember bracket they are $42 each plus freight
cheers Andy
									cheers Andy
Thanks for info
Thanks guys for tyhe quick response, will get back to you prob tomorrow, am super busy right now, Pete
						- brumbyrunner
got the full set of 4 rears (superPro was the brand - they're blue, and all the same size inner and outer) for $65 from *cough * cough* burson's, though i think the retail on them is a bit more and the guy on the phone thought i was a trade guy. if you want the part # i'll have a scavenge around (if you doing this yourself - use lots, i mean lots, of grease)
Cheers, L-BJ
						Cheers, L-BJ
- subalex
I'm just going through the process of changing over all the front and rear bushes to Nolathane and I've bought the rear ones with the metal sleeve so that means removing the original sleeve. This has proven very difficult to do. If I did this again I'd buy the bush kit for the rear that is listed as reusing the original sleeve.
I've tried just about everything to remove the original sleeve from the trailing arms but they're well and truly stuck. I've tried hacksawing through in a few locations but it still doesn't crack the seal between the metals. Advice from an engineer is now to grind it all away to vitually nothing and it should finally break through. Anyone found the same problem? Better, simpler ideas?
'91 Sportswagon - 3" lifted, 14" speedys, 27" Nankangs + lots of small details improved. Wouldn't mind some extra grunt from an EJ.
						- brumbyrunner
You need a shop press to fit the steel sleeved ones. It’s the only way to do it....
Nolathane do have a bush that installs in the original shell......
I can supply the above Nolathane bush kit for $60 + P&H...
0438 887 746
0438 887 746
