Lift Kit advice
Chad241WRC
Lift Kit advice
Post by Chad241WRC » Fri Jul 11, 2008 5:04 pm
Ok boys need some direction and advice.......
I've got a MY 1800 Wagon, which i just bought the 14inch desert rats with 27inch rubber off RSR555. They look sweet on the car and fit with the Factory adjust ment, but you cant turn the front wheel obviously.......
So my question is What are the options for lift kits out there???? I see there is BYB but it seems hard to get in touch with them, and then theres the Scorpian Subaru one which look farken fantastic but does cost a fair bit too......
Also after doing the lift will i still have to manipulate the body work a little to ensure no rubbing??
Sorry for the questions but i couldn't find a complete straight answer doing a search through the forum.
Thanks in advance boys, the sooner this is sorted the sooner I'm out on those tracks........ :mrgreen:
See God then Brake........... :twisted:
heath
Post by heath » Fri Jul 11, 2008 5:29 pm
iv built all my lift kits myself it isn't hard and its cheap. just make sure you use high tensile bolts. i think for all the bolts on mine it cost about 35 bucks. it only took me an my mate 1 day to build and install the one i'm runnig in my sedan. and we also changed it from 2wd auto to a 4wd dual range manual on that same day(the trick is dont drink to much) you also have to cut the front of the car under the bumper but that is easy i'll try put a couple of picks of where i cut when i get my camera back of my mate.
Chad241WRC
Post by Chad241WRC » Tue Jul 15, 2008 1:46 pm
Thanks for that info........... anyone else.......
just after info
brumbyrunner
Post by brumbyrunner » Tue Jul 15, 2008 8:02 pm
Have you sent Dave (subiwankanobie) a PM? He's not that hard to get hold of.
Personally, I don't know why you'd bother building a lift kit when you can buy one all pretty and plated, for a few hundred bucks. You don't have to work out your strut-top camber and steering extension either.
Settlement Creek Racing
Post by El_Freddo » Wed Jul 16, 2008 12:27 am
brumbyrunner wrote:Personally, I don't know why you'd bother building a lift kit when you can buy one all pretty and plated, for a few hundred bucks. You don't have to work out your strut-top camber and steering extension either.
Because some people enjoy making their own stuff for their car and take pride in it. I realise that some people lead busy lives and may not have their own equipment to do the work so I can understand their position too.
But yes, as Brumbyrunner has said, SWK is the one to talk to.
soobs_rule_m8
Post by soobs_rule_m8 » Tue Jul 29, 2008 8:51 pm
Thinking of doing the same myself. Heard rumours lifting shortens the life of the CV's. Can anyone confirm this? Must admit the idea of buying a kit is easy but I prefer to make what I can myself - and when it comes to being tight with bucks - pick me.
91 L series wagon 4wd. standard stuff like mags, tint, cent lock. import donk. No pics.
brumbyrunner
Post by brumbyrunner » Tue Jul 29, 2008 10:57 pm
A body lift has absolutely no affect on the lifespan of CVs.
Imagine the complete engine, drivetrain, suspension as a seperate unit to the cabin (body). Raising the body 50mm or 500mm is not going to do anything except chage the centre of gravity.
soobs_rule_m8
Post by soobs_rule_m8 » Tue Jul 29, 2008 11:04 pm
I was under the impression the usual lift kit extended the height of the suspension, therfore increasing the angle on the CV? What is the point - other than looks - of raising just the body?
SuBaRiNo
Post by SuBaRiNo » Tue Jul 29, 2008 11:09 pm
Point is, by raising the body you can put bugger wheels on. This acheives greater ground clearance. And your right... looks awesome.
A lift is almost pointless without the big wheels to go with it. Almost.
Dave
Chrus
Post by Chrus » Tue Jul 29, 2008 11:10 pm
Raising the body allows (in some cases) fitment of larger diameter tyre/wheel combo, raising the vehicle even more :cool:
edit:bit slow on the typing side of things
MY05 WRX STI Spec C Type Ra
MY05 Legacy Outback LLBean
89 Legacy RS Turbo
soobs_rule_m8
Post by soobs_rule_m8 » Tue Jul 29, 2008 11:18 pm
No drama's. I will have to look into this further. The kit the old man put on his Brumby years ago fitted onto the top of the shocks, which is why I thought tha angle of the CV 's was increased. I'll search for the thread on "body lift".
Post by AndrewT » Wed Jul 30, 2008 12:20 am
If it ONLY had lift components ontop of the shockies then yes, CV angle would be increased and cause them to flog out pretty quick. If it's a proper body lift kit then it will have also included lift blocks for the rest of the car like the engine crossmemeber. Dropping the engine crossmember down by the same amount means the CV angles return to pretty much their original position.
Suspension lift increases CV angle.
Body lift doesn't.
Outback bloke
Post by Outback bloke » Wed Jul 30, 2008 6:30 am
If you know nothing about lift kits then you are better off buying one. There is a lot more to it to get it right than people make out. Also, a lot of the "home" made kits are very dodgy (not saying any one in particular) and is the reason that the transport department crack down on things.
If you attempt to make a kit yourself be prepared to put in a lot of time to get it right.
Post by El_Freddo » Wed Jul 30, 2008 2:20 pm
Outback bloke wrote:If you know nothing about lift kits then you are better off buying one. There is a lot more to it to get it right than people make out. Also, a lot of the "home" made kits are very dodgy (not saying any one in particular) and is the reason that the transport department crack down on things.
Hey OB, I'm looking at making my own lift, could you PM me anything that I Should know before I start?
It shouldn't be too dodgy, I don't want it falling apart or being a hazard to other road users and I've got a parts car to "develop" it with, meaning no down time on my daily driver...
Outback bloke
Post by Outback bloke » Wed Jul 30, 2008 3:41 pm
A basic guide is 6mm offset per inch of lift, weld in anti-crush tubes if using steel box section, fit 2" blocks to the gearbox area with a 3" lift and 40mm blocks with a 2" lift, same size blocks on the centre carrier bearing as the gearbox, make sure your welds are good before you do the steering, do not heat the steering too much and use high tensile bolts.
Post by El_Freddo » Mon Aug 04, 2008 6:29 pm
Outback bloke wrote:A basic guide is 6mm offset per inch of lift, weld in anti-crush tubes if using steel box section, fit 2" blocks to the gearbox area with a 3" lift and 40mm blocks with a 2" lift, same size blocks on the centre carrier bearing as the gearbox, make sure your welds are good before you do the steering, do not heat the steering too much and use high tensile bolts.
Cheers OB, it may be a little while off yet - gotta wait for uni to finish and the weather to warm up/dry out a little bit first.
With the 6mm offset per inch, this is only for the front strut tops correct? And will this address the L series \-/ to more like /-\, I think its camber I'm talking about.
soobs_rule_m8
Post by soobs_rule_m8 » Wed Aug 06, 2008 6:21 pm
Where's the best place around Perth or even better - Bunbury to pick up a lift kit and about how much are they?
Chad241WRC
Post by Chad241WRC » Thu Aug 07, 2008 3:15 pm
Its either a Scorpian Subaru Kit or a Backyard Boys Kit (on this forum) for the suby, and there both in the eastern States..... going through the steps now myself....
Chad
Stretch
Lift Qustion
Post by Stretch » Mon Aug 18, 2008 5:55 pm
Sorry for my ignorance but I am new to the Subby gang. I have an 85 L-Series Wagon that I am in the midle of replacing the head gaskets on the EA82 that is in it. I was wandering what do you get in a 2" lift kit, how much do I need to pay and from whom. I am in Newcastle NSW.
Chers
Stretch
Suby Wan Kenobi
Post by Suby Wan Kenobi » Tue Aug 19, 2008 9:25 pm
A lift kit is composed of spacer blocks to space your driveline away from your body, this enables you to fit larger wheels giving you more underbody clearance.
PM sent
The long road ahead
