Page 1 of 2
Gen II Outback Trailing Arm Mounts
Posted: Fri Jun 27, 2008 4:56 pm
by __JC__
Anyone know the part number?
Jake.
Posted: Fri Jun 27, 2008 8:36 pm
by daza
These were ordered as 99 Outback trailing arm brackets.
The comparison shots are with gen1 series1 Lib.
Currently trying to determine whether the 99's are any different from the 98's?
Daza.
Posted: Sat Jun 28, 2008 12:45 pm
by stamp_licker
Daza the 98 is a cross over model,Gen3 started towards the end of 98,so you've got gen 2 and 3 in 98.Not a 100% but i think there were rear suspension changes.Kind of confusing cause those brackets all look similar just hole position varies.
Posted: Sat Jun 28, 2008 2:10 pm
by daza
Thanks Will,
The brackets i have i mis-ordered, 99 instead of 97, but they fit the Impreza fine and the holes are the same as the gen 1 series1 by eye.
So my theroy is that the Outback trailing arm bracket didn't change from gen2 to gen3.
Daza.
Posted: Sat Jun 28, 2008 4:30 pm
by __JC__
Thanks heaps for the pics, the bolts that fix the mount to the chassis look spot on, as long as the trailing arm bolt is set back then it'll be an improvement on what's currently there. I remember Dane posting that the difference is about 8mm.
How much are they worth?
Posted: Sat Jun 28, 2008 7:47 pm
by Point
couldn't you just mod the original ones by re-drilling and welding a washer in the new position? doesn't look like that much of a difference to me
Posted: Sat Jun 28, 2008 11:25 pm
by daza
__JC__ wrote:How much are they worth?
The local holden dealer stung me $53 each for them.
(Yes i have to go to a holden dealer for Subaru parts)
Daza.
Posted: Sun Jun 29, 2008 9:26 am
by AlpineRaven
Point wrote:couldn't you just mod the original ones by re-drilling and welding a washer in the new position? doesn't look like that much of a difference to me
Nah can't be done as the outback ones are about 80mm taller.
Posted: Thu Jul 03, 2008 8:43 am
by __JC__
daza wrote:These were ordered as 99 Outback trailing arm brackets.
Daza.
Hi Daza,
Been doing some research and those brackets are early forester. I didn't get to check for myself but a wrecker in Melbourne said he put them side by side with Gen II Liberty mounts and said there was no difference.
I was hoing they'd be an alternative to the Gen II OB mounts
20520AC030 (RH) and
20520AC040 (LH) that are a 3 week wait x Japan atm.
Posted: Thu Jul 03, 2008 8:52 am
by FROG
part number for lh is wrong i think
Posted: Thu Jul 03, 2008 9:04 am
by yarney
Both brackets are the same i got them on my liberty
Jan
Posted: Thu Jul 03, 2008 9:09 am
by FROG
__JC__ wrote:
I was hoing they'd be an alternative to the Gen II OB mounts 20520AC030 (RH) and 20528AC040 (LH) that are a 3 week wait x Japan atm.
liberty from
08-1993 to 11-1998 are the same part numbers
lh number is 2052
0 AA 040 btw
cheers Andy
Posted: Thu Jul 03, 2008 11:27 am
by vincentvega
mate that is incorrect.
I have removed liberty parts and fitted outback ones. They are very different.
Posted: Thu Jul 03, 2008 11:42 am
by FROG
Interesting Ill Look Into It More But Fast Gives Me The Same Part Number For Those Years I Mentioned
edit * Just looked again and thats what its telling me for the years ive mentioned but stranger things have happened
id believe you over fast anyway
cheers
Posted: Thu Jul 03, 2008 12:13 pm
by __JC__
FROG wrote:part number for lh is wrong i think
Thanks Frog, I stuffed it up typing it in.
Correct numbers for the
OB trailing arm mounts/brackets are:
20520AC030 (RH)
20520AC040 (LH)
They are different to Liberty as Dane says, it's only Daza's forester brackets that are the same (as far as physical dimensions go)
Posted: Thu Jul 03, 2008 1:30 pm
by vincentvega
Frog can you compare 1994 LX AWG Wagon and 1996 Outback in Subaru Fast and see what comes out?
I know for sure the parts are different for those cars. I did one last year
Posted: Thu Jul 03, 2008 1:34 pm
by FROG
Says The Same Again Wtf
Im Finding This A Little Strange
Posted: Thu Jul 03, 2008 1:39 pm
by vincentvega
mate subaru fast is far from reliable! i'm sure you already know that
Posted: Thu Jul 03, 2008 1:47 pm
by FROG
heck yeah
I just realised tho this is my fault the outback part numbers are AC and the liberty part number is AA the rest of the part number is same
MY BAD "HIDES IN SHAME"
BAD ANDY NOT READING PROPERLY
Posted: Thu Jul 03, 2008 2:08 pm
by Wilbur
vincentvega wrote:mate subaru fast is far from reliable! i'm sure you already know that
Just leave it at FAST in general. We use it too
