Gen II Outback Trailing Arm Mounts
Anyone know the part number?
Jake.
Jake.
These were ordered as 99 Outback trailing arm brackets.
The comparison shots are with gen1 series1 Lib.
Currently trying to determine whether the 99's are any different from the 98's?
Daza.
Daza.
- stamp_licker
Daza the 98 is a cross over model,Gen3 started towards the end of 98,so you've got gen 2 and 3 in 98.Not a 100% but i think there were rear suspension changes.Kind of confusing cause those brackets all look similar just hole position varies.
Building a hardcore postie:D
Nah can't be done as the outback ones are about 80mm taller.Point wrote:couldn't you just mod the original ones by re-drilling and welding a washer in the new position? doesn't look like that much of a difference to me
Hi Daza,daza wrote:These were ordered as 99 Outback trailing arm brackets.
Daza.
Been doing some research and those brackets are early forester. I didn't get to check for myself but a wrecker in Melbourne said he put them side by side with Gen II Liberty mounts and said there was no difference.
I was hoing they'd be an alternative to the Gen II OB mounts 20520AC030 (RH) and 20520AC040 (LH) that are a 3 week wait x Japan atm.
- FROG
part number for lh is wrong i think
- FROG
liberty from__JC__ wrote:
I was hoing they'd be an alternative to the Gen II OB mounts 20520AC030 (RH) and 20528AC040 (LH) that are a 3 week wait x Japan atm.
08-1993 to 11-1998 are the same part numbers
lh number is 20520 AA 040 btw
cheers Andy
- vincentvega
- FROG
Interesting Ill Look Into It More But Fast Gives Me The Same Part Number For Those Years I Mentioned
edit * Just looked again and thats what its telling me for the years ive mentioned but stranger things have happened
id believe you over fast anyway
cheers
cheers
Thanks Frog, I stuffed it up typing it in.FROG wrote:part number for lh is wrong i think
Correct numbers for the OB trailing arm mounts/brackets are:
20520AC030 (RH)
20520AC040 (LH)
They are different to Liberty as Dane says, it's only Daza's forester brackets that are the same (as far as physical dimensions go)
- vincentvega
- FROG
Says The Same Again Wtf
Im Finding This A Little Strange
- vincentvega
- FROG
heck yeah
I just realised tho this is my fault the outback part numbers are AC and the liberty part number is AA the rest of the part number is same
MY BAD "HIDES IN SHAME"
BAD ANDY NOT READING PROPERLY
