Camber / Caster Tool
Posted: Fri Jun 13, 2008 2:50 pm
by Matt
Posted: Fri Jun 13, 2008 11:21 pm
by AlpineRaven
In my opinion, I dont see why the magnetic thing would work because of ground level and you'll need to put spot on area - hence it could be wrong and I could be wrong.
the wheel alignment thing - lots to muck around as Ive seen someone doing it - just lot easier and accurate if you get it computerised/professionally done!
Okay for backyard mechanic for quick alignment before getting on the road but you still would get it properly aligned. I havent seen one of these in Australia.
My 2c worth.
Posted: Sat Jun 14, 2008 6:25 am
by brumbyrunner
It would be interesting to know if either of those things worked acurately enough.
I use a square and a rule to measure camber and a tape measure to check toe. I can't see the point in measureing caster, it's more of a driving preference/handling thing.
Posted: Sat Jun 14, 2008 1:21 pm
by discopotato03
It's handy when you can so that both sides can be made the same .
Cheers A .
