Because I have Liberty struts in the front for the crossbred conversion (I'm happy with this height) but the rear springs I have are from a wagon, which makes it too tall in the rear.Brumby Kid wrote: Why are your springs/ struts at different heights?
Don't you have 4 struts the same size?
This is because the wagon has taller, stiffer springs to support its heavier rear end.
Im trying to get it sitting level, but trying to avoid buying the wrong gear by researching thoroughly first
As its sitting now
Front arch 640mm from ground
Rear arch 710mm from ground
125mm to centre of bolt
260mm compressed with empty fuel tank and boot
Im pretty sure its pink and orange in this clearer pic
