Stabilser Bar-Realignment
- subybrumby
Hi guys
Quick question...I am in the middle of the Brumby/L series lower control arm conversion. I am probably doing it a bit different but have used the XD ford radius rods.
The Stabiliser bar does not quite line up with the radius rods to reattach...
I bet the stabilser bar is spring steel, Can it be heated and realigned or some other trick??? I have access to some blacksmiths..should I talk to them??
Only if you want to weaken it.subybrumby wrote:Hi guys
If its spring steel it will have been heat treated for the correct characteristics. If you heat it hot enough to re-align it or take it to a blacksmith then that will ruin the heat treatment.
Rob
- subybrumby
- subybrumby
I'm not sure on re-shaping it, and I haven't done this conversion myself....but I think you may have to start looking for an alternative sway bar to use, perhaps from a different model of car. An L series one might be nearer to the size you need.
Otherwise you could consider not running a front sway bar at all. I know a few people who do this. Naturally your road handling characteristics will be downgraded but this is an advantage for offroading as it gives you more wheel travel.
EZ30 L series - Monsterwagon
- subybrumby
- discopotato03
In the past people used to redrill the rod or the arm when doing larger radius rods on the cheap . In Rally apps they tend to bend/break most likely because Ford made them to a price ...
If serious SWR can have them made from 60T rated steel and then they survive almost anything .
As for the anti roll bar , they need to be altered by people who make them for a living . If in Sydney and get stuck let me know and I'll see what I can do .
Cheers A .
Cheers A .
I don't know if this is also the case on the Brumby but for the L series due to the inherent understeer the cars have when pushed hard it is not uncommon to remove the front stabiliser bar for competition use, particuarly tarseal. So depending on your end use leaving the bar off altogether may be an option?
									85 Leone RX EJ20T Rally Car - plus spare rolling shell
91 Facelift 2.2 GX 4WD Legacy - SOLD
96 RSB Legacy
96 RSB Legacy
- brumbyrunner
- subybrumby
Bend it without heat, you will get it on there, trust me i did mine the same way.
'86 Brumby - Dual Port Heads, 5 Speed Dual Range, Custom Cam, Tuned Weber, Tuned Suspension, 2" Body Lift Kit, LSD, 14" rims, 2.25" Exhaust, Snorkel, Dual Batteries, DVD Player, UHF, VHF, etc. Offically now part of the 350, 000 km Club! And still pulling like a freight train.
"Claudia"
"Claudia"
- Suby Wan Kenobi
If its only a small amount it has to be bent then as suggested cold bending will be fine or if you are using it offroad then you could consider leaving it off, just remember you will have to slow down a bit around corners. You could Adapt an L series sway bar but you will have to make mounts and weld or bolt them to the MY crossmember.
The long road ahead
						The long road ahead
- subybrumby
Thanks for all that...I'll go for the cold bend..its only got to move about a thickness of the bar...
I said I would post some photos...they're not that flash...
I am just waiting for my new tierod ends on order...
new falcon radius rods..using same holes and bolts..tried to make it neat
[ATTACH]721[/ATTACH]
Wheels now straight..stick out a bit with L series arm..bit of neg camber if anything
[ATTACH]722[/ATTACH]
[ATTACH]723[/ATTACH]
- subybrumby
- subybrumby
hey...i like that fender chop.
can also see how much the strut is bent aswell.
bit of extra strut top pressure never hurt anyone
that wuld be the way to go to fit some nice 30 inchers or something. (along with a 6 stud conversion )
)Wagon is no longer....
- subybrumby
