Found something interesting today
- Silverbullet
While I was moving stuff around outside today I came across the old front struts originally out of my wagon. Then I remembered something I read on here about some of these cars having rebuildable shock absorbers, for the really early models which are no longer available. My car being an 81' and having never had the front struts replaced that I can remember I started to wonder. I've looked at these in the past and thought that top plate looks like it was spot welded on. May have even attacked it with a big wrench once before but gave up because of effort required
Anyway today I gave them a proper go with a bigger wrench and a crow bar and was surprised when the top started turning
So is there any real use for these? Are they better than the non-rebuildable struts in any way?
- Suby Spanner
Cut, add some extra tube and use the Toyota cartridges for 200mm of travel and 2in longer front struts to use with a lift without strut lift blocks.
- Silverbullet
Thanks for that Phiz, got me thinking about this longer strut idea again Now it seems that much easier for me to accomplish.
I measured the old shock and checked in the FSM for its travel specs. Stock for 4WD wagon is 421mm closed and 521mm fully extended for 100mm travel. So if I was looking for longer inserts I would be looking for 200mm travel, 421mm closed and 621mm fully extended? Using this Monroe catalog search function punching in the above numbers when searching for cartridges comes up with a few results.
24-0625+ for a 77' - 80' Mitsi Sigma
24-0902+ for 62' to 66' (!) Ford Cortina
25-0229+ 89' to 92' Ford Corsair, Nissan Pintara rear shocks
25-3418+ 70' to 73' Nissan 1200 and 120Y
Can't find the diameter of these anywhere in the catalog. I guess the way to find out if any of these would work is either to ring up Monroe and bore the parts guy or pull a few off a wreck at U-pull it to see?
