2inch body lift and 3inch strut lift.
L. Series. Has anyone got any feedback on a l series with a 2inch body lift, with3 inch strut lift.....therorticaly it would only equate to a 1 inch suspension lift.
I am thinking I'll do this on my L series. A 2inch body lift all round was good, so I can't imagine a extra inch on the shocks would produce much more camber?
Thoughts/experiences?
- TOONGA
My vortex has a 2 inch front and back strut lift, only the crossmember was lowered 2 inches so the EJ22 would fit. I have no problem with camber, it was just a bunfight to get the front struts back in.
You won't have a problem with camber as long as the blocks have the right offset.
this is how my vortex sits with the strut lift
You'll chew through drive shafts like no tomorrow - but if you're still keen go for it, swapping strut lift is relatively easy - this is why owners of the EJ series vehicles do it, and they can get away with it due to the wider wheel base - less angle on the CV joints and the AWD shares the driving load between all four wheels rather than just two.
- Brumby Kid
Really? A 1" suspension lift will do that? I thought you could get away with 2" before this starts to become a problem.
We're talking a difference of one inch between the engine/gearbox crossmember/rear subframe and the struts/rear shock assemblies. My "all round" three inch lift and springs has a one inch height difference between crossmembers and struts, CVs go ok. But add another inch to the struts and you'll definitely be in trouble!Brumby Kid wrote:Really? A 1" suspension lift will do that? I thought you could get away with 2" before this starts to become a problem.
You can get away with the 2 inch in EJs due to their wider body/track width - the EJs run a longer shaft which in turn means less angle on the CVs. Make sense?
- TOONGA
Thanks Ive still got a bit to do before jetcar beach readypzs wrote:Thanks mate I got 2 2inch lift kits laying around I mod the struts block to 3inchs....that is a nice vehicle you got there
under the front of my vortex 2 inch strut lift + engine crossmember, no gearbox or radius plate blocks.El_Freddo wrote:You'll chew through drive shafts like no tomorrow - but if you're still keen go for it, swapping strut lift is relatively easy - this is why owners of the EJ series vehicles do it, and they can get away with it due to the wider wheel base - less angle on the CV joints and the AWD shares the driving load between all four wheels rather than just two.
under the rear of my vortex with just the rear shock spacers.
Remembering that the vortex is built on the "L" chassis
- Silverbullet
I found myself staring at the rear end of a modern small 4WD type thing that had CV shafts on the rear, in envy of it's completely neutral dead level driveshaft angle! The angle on the old Subies is a real PITA.
Yeah sorry mate, didn't see that the first time around! I'm going to pin that on the late night!TOONGA wrote:front shaft is shown in first picture Bennie
As for your angles, the front looks about the same as Ruby Scoo's, the rear is definitely on a sharper angle than my rear end without much weight in the back.
I'll have to get some pics to compare
Wind the back suspension down and they go level on the back. Fronts are most likely always going to have some angle.Silverbullet wrote:I found myself staring at the rear end of a modern small 4WD type thing that had CV shafts on the rear, in envy of it's completely neutral dead level driveshaft angle! The angle on the old Subies is a real PITA.
Doug
- TOONGA
They are MX5 / Miata front coil overs
they probably looked like this when new.
http://www.good-win-racing.com/Mazda-Pe ... d=gXNsn4Mg
I got them when I was working at a wrecker in Perth they were on a front cut and if I hadn't grabbed them, they would've been crushed with the reast of the stuff that wasn't needed.
I had them on my brumby they were too rigid, but work really well on the vortex as it has more weight in the rear than the brumby.
This is how they were installed on the brumby.
showpost.php?p=166246&postcount=593
showpost.php?p=166247&postcount=594
Paul (RSR55) has mentioned on facebook running with a set of commodore air adjustable shocks without a spring in the mix. Apparently the shock works as a spring - although I've always thought they were meant to work in conjunction with a spring...
Keen to get a reply on that question from Paul. Also keen to give this a go, just need to know exactly which model to use.
Yeah it is Tambox. Never thought of them as grader blades until I'm getting majorly stuck!tambox wrote:Bennie, is that photo of your rear diff mounting currently what you are running.
There is a simple mod to get rid of those "grader blade" problems with the rear mounting bar.
Would like to see what you've got
Pretty simple.
For 50mm, remove the lift blocks from either end of the bar.
Weld a piece of flat bar as a "fill in" for the center, cut it curved to fit below the existing mounting holes.
Drill the holes 50mm lower, I cut the nut cover off and move it down 50mm as well.
Lets the inner axle joints on the diff act as little wheels in a handy place.
Never damaged anything because of this mod, but I'm sure there will be someone else that can.
There was even a theory about welding little paddles on:), still a theory.
L serious, still.
Pretty simple.
Put it back without lift blocks.
[img][IMG]http://www.ausubaru.com.au/picture.php? ... ureid=2215[/img][/IMG]
L serious, still.
