polyethylene blocks???
- brumbybear
hi guys just wondering if you could use poyethylene blocks to body lift an 89 brumby?? or wouldnt it work...
cheers lasty
cheers lasty
Im looking for a cheap second hand 2-4" lift kit for my brumby... if u have one pm me plz
- Wraith
Standard polyethelene would wear way too quickly. Its just too soft. Go for UHDPE (Ultra High Density Poly Etheylene). Much better wearing characteristics.
I use the stuff at work all the time. I have turned up bushings out of it for various tools and what not, and they are holding up very well.
Another you might consider is Nylon, which is available in sheet form as well.
Why do you want to go this route??? To cut down weight presumably???
Destroy waves, NOT beaches.
1990 L Sportswagon (Mine)
1988 L Touringwagon (Hers)
1998 Liberty GX Wagon (Ours)
1987 L Touringwagon (SOLD!!)
1986 L Jap Import Turbo wagon (SOLD TO TIMMO!!)
1986 L RX Turbo wreck (SOLD TO TIMMO!!!)
- ScubyRoo
I've heard of lift kits for hilux's made out of plastic stuff - maybe that which you're talking about?
ummm i cant see why you need wear capabilities in lifting blocks, if you do the bolts up tight and they go all the way though instead of threading the polyethelene then you want crush characteristics and not wearWraith wrote:Standard polyethelene would wear way too quickly. Its just too soft. Go for UHDPE (Ultra High Density Poly Etheylene). Much better wearing characteristics.
pickstock racing fabrication
pickstock racing photography
GETDIRTYCLOTHING
GETDIRTYCLOTHING
- brumbybear
