Brumby Suspension Differences?
I'm not sure if this is the right section so please move if it is not.
I have searched the forums and cannot find a distinct answer.
I have a 90 Brumby and my fatherinlaw has an 86.
One thing he has noticed is that his rides alot harder than my 90 and others he has driven.
He was wondering if the Brumbys came out with different suspension set ups? especially in the rear.
Additionally, I have noticed alot of people referring to some Brumbys as 'MY'. I was under the impression that MY stood for Made Year and was a generic term for all cars and is something that Subaru specifically introduced. Is it a specific series of Brumby?
Never use big words where diminutive ones would suffice.
						- Proton mouse
I'm not aware of any factory differences in spring/torsion bar rates throughout the gen 2 Brumby's but there are 2 possible reasons
why yours and his may feel different.
Main one would be that the adjustment bolts in the centre of torque tubes might be set at differing amounts.
Second could be that either of them might have had a wagons rear end put in (after an accident etc) which don't have as thick a torsion bar as the utes and so would feel softer.
Not 100% sure where 'MY' (model/year as far as I knew it to be) came from, as it isn't stamped anywhere on the chassis and
does not appear in any literature when ordering from parts suppliers!! None the less, it is the colloquial term used here in OZ
for any vehicle factory fitted with the venerable EA81 donk, i.e. 82-84 Leone coupes, sedans and sportswagons and Brumbys up to 92.
Cheers, John
Cheers, John
Yes there could be a number of reasons why they feel different. I would suspect that the condition of the shock absorber and rubber bushes conditions would be the main reasons for this.
MY stands for Model/Year in the later EJ model range. In the case of the early 1979 to 1984 wagon, sedan, coupe and hatch, this was called the MY1800 on the service manual. The ute was called MV1800 as these ran a different floor stiffening. Most people just call the ute version MY just because they used all of the same mechanicals and some body panels as the MY series.
Thank you all for your responses.
In relation to the MY thing, I put this question to a few people that I know who own Brumbys and they hadn't heard of them being referred to this, hence the question here.
Now to the suspension question. My father-in-law has changed bushes and shockies in an attempt to soften the ride. I will check out the bolt suggested by Proton Mouse as I will have an opportunity to have both on hoists side by side this weekend.
Finding this forum may have been a very bad thing for me and my wallet lol. I am in the middle of house renovations, hence the long awaited purchase of a Brumby (had a legitimate reason/excuse for the missus lol), so money isn't the most abundant thing
						Ditto, I used the same excuse on my missus! Picked up the brumby the same day we picked up the house keys. Great minds think alike!zookcruzr wrote: I am in the middle of house renovations, hence the long awaited purchase of a Brumby (had a legitimate reason/excuse for the missus lol), so money isn't the most abundant thing
Sorry to hijack this thread but while we are discussing wagon vs ute suspension differences, does anybody know the difference between wagon and brumby rear shocks? Are they interchangeable?
- Proton mouse
If you are talking MY series wagons then they are the same as and interchangeable with the Brumby shocks.liteon wrote:Sorry to hijack this thread but while we are discussing wagon vs ute suspension differences, does anybody know the difference between wagon and brumby rear shocks? Are they interchangeable?
If you want a beefier shock you can use the front shocks from an FJ45 Landbruiser, but you do have to fiddlefart
with bushes a bit.
Just found this old post.Proton mouse wrote:I'm not aware of any factory differences in spring/torsion bar rates throughout the gen 2 Brumby's but there are 2 possible reasons
Cheers, John
Just to clarify, from this post I am reading the Brumby had a heavier rear torsion bar than the Wagon.
Is this correct ?
If so, anyone have any specs on both bars ?
Is there any advantage in fitting a Brumby torsion bar to the rear of a Wagon to give a heavier spring rate ?
- Proton mouse
I just found this newer post on an older post that I hadn't answered!! For some reason I don't think I got a notification?? Anyhow....Cliff R wrote:Just found this old post.
Is this correct ?
Yes the Brumby had a heavier rated torsion bar for load carrying ability, but as for the exact specs/rating I am unaware. The part numbers of the different 'MY' T'bars are....(with thanks to FROG from another post)
721021140 rh brumby
721021150 lh brumby
721021160 hatchy and sedans rh
721021170 hatchy and sedans lh
721021060 rh wagon
721021070 lh wagon
I guess the advantage of fitting one to a wagon would be a slightly firmer ride and/or higher load carrying capacity
Cheers JB
