Jes Zek has done some great write ups on the conversion here :
http://www.ultimatesubaru.org/forum/top ... rake-swap/
http://www.ultimatesubaru.org/forum/top ... -solution/
Cheers, Bantum ...
89 Brumby Brake Improvments
- Bantum
Fitting kit ...
Also came across these :
From here : http://www.subaru4you.co.uk/brakes/brak ... gkit.shtml
Don't know if they would work or not, but may be a possible alternate solution in to making late model calliper's fit EA stuff ? ...
Cheers, Bantum ...
Cheers, Bantum ...
- Bantum
Upgrades ...
Was also looking at these as a possible upgrade :
Found here : http://www.xcceleration.com/itemdetails.cfm85.htm
You would need 17" wheels to clear the calliper /rotor & could possibly get the 'hat' to bolt up to back of L series hub + use the fitting kit above for the Caliper - dunno if it would work though.
Thoughts ?
Cheers, Bantum ...
Thoughts ?
Cheers, Bantum ...
