I have signed up to Wikidot under Subyroo (of course ), do I also need an invite from you for the site?60766244 wrote:Cool
Keep us updated as to general progress! Not sure yet if the wiki will inform me of it - it should, but, not sure.
New: AUSubaru Tech. Manual up - ausubaru.wikidot.com
- Bantum
Updates ...
No worries ...60766244 wrote: ... Keep us updated as to general progress! Not sure yet if the wiki will inform me of it - it should, but, not sure ...
Here is a short list of things I'm looking at now :
- Propose adding one page for gear boxes ( similar to engine list )
- Revising / update 'model' page to include all Aussie Subaru's,
- Adding to & Fixing Engine list,
- Plus any thing else I come accross that's not right etc ...
P.S. - Another thought was adding links to other non Aussie 'models' on the list - what does everyone
think ?
P.P.S. - I've added 'library' to the main list & moved relavent items under it ( seemed to make the most sense ) - Ok with you ?
P.P.P.S - I also wanted to update the links to text / title headings - anybody know how to do it in Wiki ?
Cheers, Bantum.
- 60766244
Sounds good. Great to see you have a handle on the site coding and things. Keep up the good work!Bantum wrote:No worries ...
Here is a short list of things I'm looking at now :Will notify you all here of any other changes made ...
think ?
P.P.S. - I've added 'library' to the main list & moved relevant items under it ( seemed to make the most sense ) - Ok with you ?
Cheers, Bantum.
"I also wanted to update the links to text / title headings - anybody know how to do it in Wiki ?"
Specifically where? I could assist here.
- Bantum
Links ...
Ok - for example: In the Engine list at top is the 'index' with headings, I want them to point to its corresponding section later in the page ...60766244 wrote: ... Specifically where? I could assist here ...
We just need to work how to do it with linky thing so that when you select / click on it, it jumps to that section - Saves you from having to scroll through a long document ...
Cheers, Bantum
P.S. - There is a list of Turbo's that should be appended to engine list ...
- 60766244
Still unsure how to get it to work without resorting to HTML coding. It's simple in HTML and can be found with a search engine. The site allows small amounts of HTML to be activated in the coding, if you have a way that needs no HTML then awesome.Bantum wrote:Ok - for example: In the Engine list at top is the 'index' with headings, I want them to point to its corresponding section later in the page ...
Cheers, Bantum
- Bantum
Links ...
Ok - I will have a bit of a play & see what works ...60766244 wrote:Still unsure how to get it to work without resorting to HTML coding. It's simple in HTML and can be found with a search engine. The site allows small amounts of HTML to be activated in the coding, if you have a way that needs no HTML then awesome.
P.S - I'm thinking of putting more stuff in the Library, stay tuned ...
- 60766244
*anticipates*Bantum wrote:Ok - I will have a bit of a play & see what works ...
- 60766244
Hey all.
Just a bump for the new AUSubaru.com wiki.
It's really simple to contribute - if you're an expert on a topic matter, or just happen to know how things should be, run through the wiki and sign up to wikidot.com, inform me and I'll make you an editor to the wiki.
Just punch out an article, drop it in the site.
If you're not tech-savvy with coding, drop me an email and I'll put in in the wiki.
The more we built it the better it'll be.
Cheers!
Cheers!
- Bantum
More ...
Where's the like button when you need it ? ...60766244 wrote: ... Just punch out an article, drop it in the site ... !
P.S. - There's heaps on AUSubaru that could be added, you just need to sift through it all ...
Sorry I've been pre-occupied with a few other things, but have progressed on the engine / transmission list & will move them into the 'library' when I get a chance ...
Ciao, Bantum ...
- Bantum
Update ...
I've just added a SPFI conversion page in a new section + revised a few pages, still heaps more to do though ...
P.S. - I've also updated the main menu on side with a new heading 'Advanced Workshop' & moved the modification sections under it ...
Cheers, Bantum ...
Cheers, Bantum ...
- Silverbullet
Any chance you could link my Hitachi rebuild thread? I see there's not much in the fuel and emissions section
showthread.php?t=23367&highlight=hitachi+rebuild
Was looking for wheel nut tightening torque & came across this:
"Outback / Forester / some Impreza models Wheels - 115mm PCD x 5 stud"
It should be 100mm PCD (at least with the SF Foz - I think 115mm came in later)
So anyway...what is the correct torque for an SF Foz wheel stud?
- Bantum
Added ...
Done ...Silverbullet wrote: ... Any chance you could link my Hitachi rebuild thread ... ?
Yeah , I've been meaning to find more, just haven't got round to it. Seems like I'm the only one doing anything atm ...Silverbullet wrote: ... I see there's not much in the fuel and emissions section ...
Cheers, Bantum ...
- Bantum
Correction ...
Noted + Corrected ...NachaLuva wrote: ... It should be 100mm PCD ( at least with the SF Foz - I think 115mm came in later ) ?
I've no idea, but when I do find out, will post it up ...NachaLuva wrote: ... So anyway ... what is the correct torque for an SF Foz wheel stud ... ?
Cheers, Bantum ...
- Bantum
Watcher ...
Sorry, must of missed this ...
First: Signup to wikidot.com - Use the same name as you use on this site so we can keep track.
Second: Go to ausubaru.wikidot.com
Third: Become a "Watcher" for the wiki - scroll down & look for a box in the lower right of screen labelled 'Watch: site' - Click on this to add your name.
Fourth: Once your name has been added & shows up on the "watchers" list, Please then PM 60766244 or post in this thread so we know who to "Invite" to the specific wiki.
Fifth: Once you've accepted your invitation to ausubaru.wikidot.com then you should be able to Edit / Add articles and improve the wiki as we go along !
Cheers, Bantum ...
P.S. - I might make this a bit clearer also on the wiki page itself ...
If you wish to contribute / become an editor :Subyroo wrote:I have signed up to Wikidot under Subyroo (of course ), do I also need an invite from you for the site?
Cheers, Bantum ...
- Bantum
No more pages ...
Hmm ...
We seem to have hit a snag, as the Wiki site is not responding to our requests for a fix to 'add' more pages ...
Can anybody help ?
Ciao, Bantum ...
Can anybody help ?
Ciao, Bantum ...
What do you mean?Bantum wrote:Hmm ...
Can anybody help ?
Ciao, Bantum ...
I can set you up something on another server if thatsw hat you're after, if you have. Way to get the data out of the other site. Do they have an API? (I haven't looked sorry,ca n next week).
- 60766244
Okay, so, made a page the usual way I made each and every other page.
http://ausubaru.wikidot.com/wiki:added- ... for-bantum
Not sure what the go is there buddy - she seems to be working great!
- 60766244
Go to the "Admin Toolbox" on the side menu there, and click "Edit this menu" on there, once there you'll see the code setup for the menu.
Follow the way it's setup there, being careful not to disturb existing pages. (Copy paste a page template, then change it's name how it should be for your specific topic for the page.
Save the changes, then go back to the home page to view your new menu item. Click on the new menu item - it will display a page asking if you'd like to make one to suit this item, since one doesn't currently "Exist" - click the link and play to your hearts content.
Also, edit the one I made to the page you've been wanting to build.
Hope I helped.
Hope I helped.
