power light flashing
AUSubaru Technical Manual. Collaborative Tech Manual for ALL Subarus.
chubby37
Post by chubby37 » Fri Oct 26, 2012 8:03 am
In my ej22 auto the power light on the dash flashes 26 (one long and 16 short).anyone know these codes?.
Thanks bill
chubby37
Post by chubby37 » Sat Oct 27, 2012 9:33 pm
Sorry that should read 26 not code 16
Post by RSR 555 » Sat Oct 27, 2012 11:36 pm
So is that 2 long and 6 short?? as 26 is not a normal code for the Subaru Automatic Transmission.
Most common issue the Subaru 4EAT gets is Duty Solenoid D which relates to the AWD system.
Are you getting any torque bind whilst turning sharply? How does the car drive?
chubby37
Post by chubby37 » Mon Oct 29, 2012 12:38 pm
Car is a front wheel drive.I get like a surge type feeling but not up in revs but like down on power.its not all the time but mostly on acceleration like a slip but its not slipping...its very hard to explain it.
Post by RSR 555 » Mon Oct 29, 2012 10:02 pm
Ok. 2WD then, I'm thinking there is break in a wire/solenoid in the system. Check all the plugs (mainly the 2 large ones at the top of the box) and make sure there is no water inside them. If that doesn't work, drain the fluid and remove the pan, clean/replace filter and check for any broken wires inside. If all good, replace pan and fill with new fluid.
chubby37
Post by chubby37 » Tue Oct 30, 2012 9:41 am
Ol I'll check that.I did just put a new filler kit I'm it and all looked good inside
Post by RSR 555 » Tue Oct 30, 2012 10:14 am
Use this method to check the codes...
http://www.surrealmirage.com/subaru/trans.html#transtip
chubby37
Post by chubby37 » Tue Oct 30, 2012 11:41 pm
Wow thanks mate....I did find a bared wire that was touching on the auto too
Return to “Tech Manual”
