power light flashing
- chubby37
In my ej22 auto the power light on the dash flashes 26 (one long and 16 short).anyone know these codes?.
Thanks bill
Thanks bill
So is that 2 long and 6 short?? as 26 is not a normal code for the Subaru Automatic Transmission.
Most common issue the Subaru 4EAT gets is Duty Solenoid D which relates to the AWD system.
Are you getting any torque bind whilst turning sharply? How does the car drive?
Ok. 2WD then, I'm thinking there is break in a wire/solenoid in the system. Check all the plugs (mainly the 2 large ones at the top of the box) and make sure there is no water inside them. If that doesn't work, drain the fluid and remove the pan, clean/replace filter and check for any broken wires inside. If all good, replace pan and fill with new fluid.
