List of Subaru Engines ...
AUSubaru Technical Manual. Collaborative Tech Manual for ALL Subarus.
Post by Bantum » Wed Oct 24, 2012 4:20 pm
Three Cylinder Engines
Subaru EF Engines :
Water Cooled, In-Line, Single Over Head Cam
  • EF-10: 1.0-litre, 997 cc, 2 Valve, B & S: 78 x 69.6 mm, Comp Ratio : 9.5:1
    Subaru Justy ( 1984 – 1987 ) & Libero ?
    • 47 bhp (35 kW; 48 PS) @ 5,000 rpm / 59 lb·ft (80 N·m) @ 3,200 rpm
  • EF-12: 1.2-litre, 1189 cc, 3 Valve, B & S: 78 x 83 mm, Comp Ratio : 9:1
    Subaru Justy ( 1987 – 1994 ) & Libero + Tutto ( Taiwan )
    • 66 bhp (49 kW; 67 PS) @ 5,200 rpm / 70 lb·ft (95 N·m) @ 3,600 rpm ( Carbi )
    • 73 bhp (54 kW; 74 PS) @ 5,600 rpm / 71 lb·ft (96 N·m) @ 3,600 rpm ( MPFI )
    • 80 bhp (60 kW; 81 PS) ? ( MPFI )
Notes : Was there a turbo version ? ... Add / Revise list - 1 Dec 2012
Post by Bantum » Wed Oct 24, 2012 4:23 pm
Four Cylinder Engines
Subaru EA Engines :
Water Cooled, Flat-Four, Over Head Valve
  • EA-52: 977 cc, B & S = 72 x 60 mm, Comp Ratio = 9.0:1
    Subaru 1000 ( 1966 – 1971 ) & FF-1 Star ( 1970 – 1973 )
    • 55 hp @ 6,000 rpm, 7.8 kg・m @ 3,200 rpm, 57 lb·ft (77 N·m) @ 3,200 rpm.
  • EA-61: 1.1 L, 1088.8 cc, B & S = 76 x 60 mm, Comp Ratio = 8.5:1
    Subaru FF-1 Star 'Sport' and Subaru 1100 G ( 1970 – 1972 )
    • 61 bhp (45 kW; 62 PS) @ 5,600 rpm, 65 lb·ft (88 N·m) @ 4,000 rpm.
  • EA-62: 1267.5 cc, B & S = 82 x 60 mm, Comp Ratio = 9.0:1
    Subaru 1300 G ( 1971 – 1972 )
    • 80 bhp (60 kW) @ 6,400 rpm, 73 ft·lbf (99 N·m) @ 4,000 rpm.
  • EA-63: 1.3 L, 1362 cc, B & S = 85 x 60 mm, Comp Ratio = 8.5:1
    Subaru 1400 Leone ( 1973 – 1976 )
    • 72 PS (53 kW) @ 6,000 rpm, 10.2 kg·m ( 100 N·m; 74 lb·ft ) @ 3,600 rpm ( JDM, em cleaned )
    • 78 PS (57 kW) @ 6,000 rpm, 10.5 kg·m ( 103 N·m; 76 lb·ft ) @ 4,000 rpm ( JDM, no em equipment )
  • EA-65: 1.3 L, ? cc, B & S = ? mm, Comp Ratio = ?
    Subaru Leone DL ( ? ) More info neded ...
  • EA-71: 1595 cc, B & S = 92 x 60 mm, Comp Ratio = 9.0:1
    Subaru 1600 Leone ( 1976 – 1987 ) & Brat / Brumby ( 1978 – 1980 )
    • 82 PS (60 kW) @ 5,600 rpm, 12.0 kg·m ( 118 N·m; 87 lb·ft ) @ 3,600 rpm ( JDM, em cleaned )
    • 87 PS (64 kW) @ 5,600 rpm, 12.3 kg·m ( 121 N·m; 89 lb·ft ) @ 3,600 rpm ( JDM, no em equipment )
    • 95 PS (70 kW) @ 6,400 rpm, 12.3 kg·m ( 121 N·m; 89 lb·ft ) @ 4,000 rpm ( JDM twin-carb, em cleaned )
  • EA-81: 1781 cc, B & S = 92 x 67 mm, Comp Ratio = 8.7:1
    Subaru 1800 Leone ( 1980 – 1989 ) & Brat / Brumby ( 1981 – 1993 )
    • 73 bhp (54 kW; 74 PS) @ 4,800 rpm, 94 lb·ft (127 N·m) @ 2,400 rpm
  • EA-81T: 1781 cc, B & S = 92 x 67 mm, Comp Ratio = 7.7:1, Pressure: 7 psi
    Subaru 1800 Leone ( 1983 – 1984 ) & Brat / Brumby ( 1984 – 1993 )
    • 95 bhp (71 kW; 96 PS) @ 4,200 rpm, 123 lb·ft (167 N·m) @ 2,800 rpm ( Turbo )
Note : There many variants of the EA-81 Engines & things that it went into ... :)
Water Cooled, Flat-Four, Single Over Head Cam
  • EA-72: 1.6 L, ? cc, B & S = ? mm, Comp Ratio = ?
    Subaru L Series 'Maia FF' and 'Maia II' ( ? )
  • EA-82: 1.8 L, 1791 cc, B & S = 92 x 67 mm, Comp Ratio = 8.7:1
    Subaru L Series ( 1985 - 1994 ) & XT ( 1985 - 1991 )
    • 84 bhp ( 63 kW; 85 PS ) @ 5,200 rpm, 101 lb·ft (137 N·m) @ 3,200 rpm ( Carb )
    • 90 bhp ( 67 kW; 91 PS ) @ 5,600 rpm, 101 lb·ft (137 N·m) @ 3,200 rpm ( SPFI )
    • 97 bhp ( 72 kW; 98 PS ) @ 5,200 rpm, 103 lb·ft (140 N·m) @ 3,200 rpm ( MPFI )
  • EA-82T: 1.8 L, 1791 cc, B & S = 92 x 67 mm, Comp Ratio = 7.7:1, Pressure: 7 psi
    Subaru L Series ( 1985 - 1994 ) & XT ( 1983 - 1990 )
    • 111 bhp (83 kW; 113 PS) @ 5,200 rpm ( Turbo, 1985 - 1986 )
    • 115 bhp (86 kW; 117 PS) @ 5,200 rpm ( Turbo, 1987 - 1990 )
Note : There also many variants of the EA-82 Engines ...
Subaru EN Engines :
Water Cooled, In-Line Four, Single Over Head Cam
  • EN-05: 547 cc,
    KH2 Subaru Rex ( 1986 )
    • 38 PS @ 7,500 rpm, 4.5 kg·m @ 4,500 rpm.
  • EN-07A: 658 cc, (Naturally Aspirated carburetor)
    KW series Subaru Vivio ( ? )
    • 42PS @ 7,000 rpm, 5.3 kg·m @ 4,500 rpm.
  • EN-07C: 658 cc, . (LPG carburetor version)
    KV3 series Sambar ( ? )
    • 40PS @ 6,500 rpm, 5.5 kg·m @ 3,500 rpm
  • EN-07L: 658 cc, (LPG carburetor version)
    Subaru Sambar & Dias ( ? )
    • 40PS @ 6,500 rpm, 5.5 kg·m @ 3,500 rpm.
  • EN-07E: 658 cc, SOHC, (Naturally Aspirated EMPi)
    Subaru Rex, Vivio & Pleo KK3 Vivio MT version ( ? )
    • 38 kW (53PS; 52 hp) @ 7,200 rpm, 53.9 N·m (5.5 kg·m) @ 5,600 rpm.
  • EN-07F: 658 cc, SOHC, (Naturally Aspirated EMPi)
    Subaru TV1 series Sambar ( ? )
    • 35 kW (48PS) @ 6,400 rpm, 58 N·m (5.9 kg·m) @ 3,200 rpm.
  • EN-07S: 658 cc, SOHC, (Naturally Aspirated SPI)
    Subaru Pleo ( ? )
    • 45 PS @ 6,400 rpm, 5.7 kg·m @ 4,000 rpm.
  • EN-07Y: 658 cc, SOHC, (supercharger EMPi)
    Subaru KV4 series Sambar Touring ( ? ) Subaru TV1 series Sambar Dias ( ? )
    • 55ps @ 6,200 rpm, 7.1 kg·m @ 3,800 rpm.
    • 43 kW (58PS) @ 6,000 rpm, 74 N·m (7.5 kg·m) @ 4,400 rpm.
  • EN-07W: 658 cc, SOHC, (minor change SPI)
    Subaru Pleo L (CVT transmission)
    • 42 kW (58 PS) @ 6,400 rpm, 74 N·m (7.3 kg·m) @ 4,000 rpm.
  • EN-07U: 658 cc, SOHC, ( mild change EMPi )
    Subaru Pleo L ( CVT transmission )
    • 44 kW (60 PS) @ 6,400 rpm, 75 N·m ( 7.6 kg·m ) @ 4,000 rpm.
  • EN-07Z: 658 cc, SOHC, ( IC supercharger with EMPi )
    Subaru Rex VX / Subaru Vivio GX ( ? ) & Pleo RM ( ? )
    • 64 PS @ 6,000 rpm, 9.1 kg·m @ 3,600 rpm .
    • 47 kW (64 PS) @ 6,400 rpm 84 N·m ( 8.6 kg·m ) @ 4,400 rpm.
Water Cooled, In-Line Four, Double Over Head Cam
  • EN-07D: 658 cc, DOHC, AVCS,
    Subaru R1, R2 & Stella ( ? )
    • 40 kW (54PS) @ 6,400 rpm, 63 N·m (6.4 kg·m) @ 4,400 rpm.
  • EN-07X: 658 cc, DOHC, ( IC with supercharger )
    ( Subaru Vivio RX-R ) ( Subaru Pleo RS )
    • 47 kW (64PS) @ 6,000 rpm, 102 N·m (10.5 kg·m) @ 3,200 rpm.
    • 47 kW (64PS) @ 7,200 rpm, 106 N.m (9.0 kg.m) @ 4,000 rpm.
  • EN-08: 758 cc, ( more info needed )
    Subaru Fiori ( 1998 - ? )
Notes : Where I have a ? - more info /correction is generally needed ...
Edits : Added a few more EJ engines ... Revised List + More added to list - 26 Oct 2012 ... Revised Diesel info - 19 Nov 2012 ... Revise list + add more details -1 Dec 2012 ... Moved FA + FB Engines to new page ... Correction to EN type + Add EA-65 & EA-72 - 22 Feb 2013 ...
Post by Bantum » Wed Oct 24, 2012 4:28 pm
Subaru EJ Engines :
Water Cooled, Flat-Four, 16-Valve, Single Over Head Cam
  • EJ-15: 1493 cc, B & S = 85 x 65.8 mm, Comp Ratio = 9.4:1
    JDM Subaru Impreza ( 1990 – 2003 )
    • 1: 97 PS (71 kW; 96 bhp) @ 6,000 rpm, 129.4 N·m (95 lb·ft) @ 3,600 rpm ( MPFI )
    • 2: 102 PS (75 kW; 101 bhp) @ 5,600 rpm, 136.3 N·m (101 lb·ft) @ 4,000 rpm
    • 3: 95 PS (70 kW; 94 bhp) @ 5,200 rpm, 140.2 N·m (103 lb·ft) @ 3,600 rpm
    • 4: 100 PS (74 kW; 99 bhp) @ 5,200 rpm, 142.0 N·m (105 lb·ft) @ 4,000 rpm
  • EJ-16: 1597 cc, B & S = 87.5 x 65.8 mm, Comp Ratio = 9.4:1
    Subaru Impreza ( 1993 – 2006 )
    • 90 PS (66 kW; 89 bhp) @ 6,000 rpm, 138.3 N·m (102 lb·ft) @ 4,500 rpm ( MPFI )
  • EJ-18: 1820 cc, B & S = 87.9 x 75 mm, Comp Ratio = 9.5:1 ( more info needed )
    Subaru Impreza, Euro & JDM Subaru Legacy ( 1993 – 1999 ) & Isuzu Aska (1990–1993)
    • 1: 110 PS (81 kW; 108 bhp) @ 6,000 rpm, 149.1 N·m (110 lb·ft) @ 3,200 rpm.
    • 2: 115 PS (85 kW; 113 bhp) @ 6,000 rpm, 154.0 N·m (114 lb·ft) @ 4,500 rpm ( SPFI )
    • 3: 120 PS (88 kW; 118 bhp) @ 5,600 rpm, 163.8 N·m (121 lb·ft) @ 3,600 rpm.
  • EJ-20: 2.0 litre, 1,994 cc, B & S = 92 x 75 mm, Comp Ratio = 9.4:1
    Subaru Impreza - Most Models + WRX in the United States ( 2002 – 2005 )
    • E: 115–190 hp @ rpm? ( naturally aspirated )
    • 2: ?
  • EJ-20N: ? ( compressed natural gas ) ( more info needed )
  • EJ-20T: ? , Rocker-style HLA, B & S = 92 x 75 mm, Comp Ratio = 8.0:1 ( Turbo, more info needed )
    • G: 220–280 hp @ ? rpm. 200 PS (147 kW; 197 bhp) @ 6,000 rpm and 260 Nm.
    • K: ditto ( Impreza WRX & STi 9/96~9/98 )
    • 5: ditto
    • 7: ditto
  • EJ-22: 2212 cc, B & S = 85 x 65.8 mm, Comp Ratio = 9.4:1
    Subaru Impreza & Subaru Legacy ( 1989 - 2001 )
    • 135–280 hp @ ? rpm.
  • EJ-25: 2457 cc, B & S = 85 x 65.8 mm, Comp Ratio = 9.4:1
    Found in Most Models ( 1995 – 2012 )
    • 165–320 hp @ ? rpm.
  • EJ-30: ?, B & S = 85 x 65.8 mm, Comp Ratio = 9.4:1 ( Special limited engine )
    ( more info needed ) ? what did this go in ?
Note : Phase I engines ( 1989 – 1998 ) and Phase II engines ( 1999 – 2010 ).
Water Cooled, Flat-Four, 16-Valve, Dual Over Head Cam
  • EJ-20D: 1,994 cc, B & S = 85 x 65.8 mm, Comp Ratio = 9.4:1
    Subaru Legacy ( 1989 - 1999 )
    • 150 hp (110 kW)
  • EJ-204: ?, B & S = 85 x 65.8 mm, Comp Ratio = 9.4:1, naturally aspirated AVCS.
    Subaru Legacy JDM ( 2003 - 2009 ) 190 hp (140 kW)
    Subaru Impreza JDM ( 1993 - 1999 ) 155 hp (116 kW)
  • EJ-20TT: , ? B & S = 85 x 65.8 mm, Comp Ratio = 9.4:1( Sequential Twin Turbo, more info needed )
    • H:183 kW (249 PS; 245 bhp)
    • R:206 kW (280 PS; 276 bhp)
    • 6:190 kW (258 PS; 255 bhp)
    • 8:206 kW (280 PS; 276 bhp)
  • EJ-25: ? B & S = 85 x 65.8 mm, Comp Ratio = 9.4:1( more info needed )
Note : Cosworth CS600 series 'High Performance Engine'
Subaru EL Engine :
Water Cooled, Flat-Four, Double Over Head Cam
  • EL-?: 1,498 cc, AVCS, B & S = 85 x 65.8 mm, Comp Ratio = 9.4:1
    JDM Subaru Impreza ( 2006 - onwards )
    • 110 hp ( 81 kW ) @ 6400 rpm, 144 N·m @ 3,200 rpm.
Notes : Revised layout & moved to new page ... more to come ...
Edits : Add more info - 3 Dec 2012 ...
Post by Bantum » Wed Oct 24, 2012 4:32 pm
Subaru FA Engines :
Water Cooled, Flat-Four, ?
  • FA-20: 1,998 cc,
    Subaru BRZ, Toyota 86 (4U-GSE) & the Scion FR-S ( 2012 - current )
    • 200 PS (147 kW; 197 hp) @ 7,000 rpm, 20.9 kg·m (205 N·m; 151 lb·ft) @ 6,400 - 6,600 rpm
  • FA-20T: Turbo ? ( not released yet )
    Subaru BRZ, Toyota 86 (4U-GSE) & the Scion FR-S ( ? )
  • FA-20 DIT: 1,998 cc,
    Legacy GT DIT sedan & Touring Wagon ( 2012 - current )
    • 300 PS (221 kW; 296 hp) @ 5,600 rpm, 40.8 kg·m (400 N·m; 295 lb·ft) @ 2,000 - 4,800 rpm
Subaru FB Engines :
Water Cooled, Flat-Four, ? DOHC
  • FB-16: 1,600 cc,
    EUDM Impreza XV 1.6i ( 2012 - current )
    • 84 kW (115 PS) @ 5,600 rpm, 150 N·m (15.3 kg·m) @ 4,000 rpm.
  • FB-20: 1,995 cc,
    JDM Subaru Forester & Impreza ( 2011 + Current )
    • 109 kW (148 PS) @ 6,000 rpm, 196 N·m (20 kg·m) @ 4,200 rpm.
  • FB-25: 2,498 cc,
    North American Subaru Forester ( 2011 + Current )
    • 170 hp, 174 lb·ft @ ? rpm.
Notes : Ran out of room again ... :( ... so I had to break it up ... might do a bit of re-organising later ...
Edit : Revised list - 3 Dec 2012 ...
Post by Bantum » Wed Oct 24, 2012 4:34 pm
Subaru EE Engines :
Water Cooled, Flat-Four, Double Over Head Cam, 16-valve, Diesel
  • EE-20: 2.0 litre, 1998 cm3, B & S = 98.4 x 80.0 mm ?
    Subaru Forester, Legacy & Impreza ( 2008 - current )
    • 110 kW (150 PS, 148 hp) @ 3,600 rpm, 350 N·m (35.7 kgf·m, 258 lbf·ft) @ 1800 rpm.
  • EE-20T: 2.0 litre, 1998 cm3, B & S = 98.4 x 80.0 mm ? ( Turbo, more info needed )
    • 110 kW (150 PS, 148 hp) @ 3,600 rpm, 350 N·m (35.7 kgf·m, 258 lbf·ft) @ 2400 rpm.
Note : There are conflicting capacity / configurations for these engines ...
Post by Bantum » Wed Oct 24, 2012 4:40 pm
Six Cylinder Engines
Subaru ER Engine :
Water Cooled, Flat-Six, 12-Valve, SOHC,
  • ER-27: 2672 cc,
    Subaru XT ( 1987 – 1991 )
    • 145 hp @ 5,200 rpm.
Subaru EG Engine :
Water Cooled, Flat-Six, 24-Valve, DOHC, Quad Cam
  • EG-33: 3318 cc,
    Subaru Alcyone SVX ( 1992 – 1997 )
    • 230 hp @ 5,400 rpm.
Note : There are several variations for this model ...
Subaru EZ Engines :
  • EZ-30D: 2999 cc,
    Outback H6, Legacy GT30 & Legacy Lancaster 6. ( 2000 – 2002 )
    • 220 hp ( 161 kW ) @ 6,000 rpm, 289 N·m @ 4,400 rpm.
  • EZ-30D: 2999 cc,
    Legacy 3.0R, Outback 3.0R & Tribeca ( 2003 – 2009 ) 2006–2008
    • 245 hp ( 180 kW ) @ 6,600 rpm, 297 N·m @ 4,200 rpm.
  • EZ-36D: 3629 cc,
    Legacy, Outback & Tribeca ( 2010 - current )
    • 260 hp ( 191 kW ) @ 6,000 rpm, 335 N·m @ 4,400 rpm.
Notes : There are various engine capacities for this model ... Revise list -1 Dec 2012 ...
Post by TOONGA » Wed Oct 24, 2012 5:35 pm
heres an EA81 you may have problems finding info for :)
Brumby Kid
Post by Brumby Kid » Wed Oct 24, 2012 6:28 pm
TOONGA wrote:heres an EA81 you may have problems finding info for :)
What the **** is that?
I want one!!!
What are those things over the heads?
Is this a DIY fuel injected EA81?
Dads Car: 02 Impreza WRX STi
Post by Silverbullet » Wed Oct 24, 2012 6:55 pm
Brumby Kid wrote: Is this a DIY fuel injected EA81?
Looks a bit like it, could be possible and I wouldn't put anything past the Aero guys. But this one hasn't got the equipment to swing a prop yet...hmmmmm :?
Post by TOONGA » Wed Oct 24, 2012 7:06 pm
Factory fuel injection :) it wasnt just the EA81 turbo that got it either.
thunder039
Post by thunder039 » Wed Oct 24, 2012 7:27 pm
TOONGA wrote:Factory fuel injection :) it wasnt just the EA81 turbo that got it either.
what car was it factory fitted to?
2004 subaru forester -gone
1989 subaru brumby- sold!
2008 zook jimny -sold!
Post by TOONGA » Wed Oct 24, 2012 7:39 pm
The MY series :)
yes Im being cryptic, I'm still looking for info myself. From what I understand it was a California based MY series (late model) that got injection. So far it is all myth and conjecture :)
Post by Silverbullet » Wed Oct 24, 2012 9:33 pm
Yet another magical mystery engine to add to the list of EA81 variations...
Post by TOONGA » Wed Oct 24, 2012 10:51 pm
Heres a site with EA81 aircraft engines that I've never seen before and it is in Queensland :shock:
http://www.foxcon.com/Subaru-EA81.html
I rather like how they have done the radiator cap.
More to add ...
Post by Bantum » Wed Oct 24, 2012 11:46 pm
TOONGA wrote: ... I'm still looking for info myself ... So far it is all myth and conjecture ... :)
Ha - I will wait to see what info you can gather - like the pic though ... :)
Thanks mate, added to list ... :)
Post by Bantum » Thu Oct 25, 2012 12:38 am
Bike Engines
Note : This List contains various Subaru engines used in bikes ...
Subaru / Fuji Engines : Polaris Engines :
Some Engines that come from Subsiduary
Note : Just show's how much I know ...
Concepts : P.S. - 'Tweety' might want to add his here ... :p
More to add ... :)
UpDates : Add Polaris ... 9 Nov 2012
Post by TOONGA » Thu Oct 25, 2012 10:31 am
Bantum wrote:Ha - I will wait to see what info you can gather - like the pic though ... :)
Myths and conjecture are extremely hard to prove :) I couldn't even find the thread on USMB where I originally found the link to the picture.
I have read elsewhere that the JDM EA81 was available in MPFI as well, without a turbo. Finding proof well...
By the way that is the turbo motor :) have a look at the oil pump. I was hoping some one else would have info on the MPFI NA EA81.
Performance Engines ...
Post by Bantum » Fri Oct 26, 2012 1:20 am
Expensive but very nice :
Cosworth Subaru Engine Assemblies
Toss in a high flow Manifold + Dry sump & you have one mean machine ... :cool:
Added to list ... :)
Outback bloke
Post by Outback bloke » Fri Oct 26, 2012 5:53 am
Just as a matter of interest, there was one of the F1 flat 12 engines advertised on ebay a few years back. $20,000 at the time. I wonder what ever happened to it.
Subaru F1 ...
Post by Bantum » Wed Nov 07, 2012 12:46 am
Outback bloke wrote:Just as a matter of interest, there was one of the F1 flat 12 engines advertised on ebay a few years back. $20,000 at the time. I wonder what ever happened to it.
Tried to find out & can confirm it was on e-bay ...
subaru-flat+12-formula-one-engine-for-sale-on-ebay
But still non the wiser ... :-|
Return to “Tech Manual”
