resetting airbags
AUSubaru Technical Manual. Collaborative Tech Manual for ALL Subarus.
handsofakiller
resetting airbags
Post by handsofakiller » Thu Jul 28, 2011 7:56 pm
I need to reset my passenger side front airbag (impreza RX MY00), any suggestions in installation appart from taking it to a subaru workshop? I can get a second hand airbag for it, but everyone says it's dangerous. I know nothing about replacing airbags, so I dont know if its true or if it is just internet hype and there is an easy way to do this.
littlewhiteute
Post by littlewhiteute » Thu Jul 28, 2011 8:30 pm
Buying secondhand airbags is like buying secondhand brake pads.
You know nothing about airbags?
Do you know anything about pyrotechnics?
Continue at your own risk.
Gary ;)
Post by TOONGA » Thu Jul 28, 2011 8:34 pm
yes buy one second hand it would be half the cost and twice the fun as you would never know when it would deploy :) having worked in a wrecking yard Ive seen how they are removed and I would never trust one
Post by sven '2' » Thu Jul 28, 2011 8:52 pm
Dealer for sure.
If you do replace them, please video it!
Subyroo
Post by Subyroo » Thu Jul 28, 2011 9:44 pm
sven '2' wrote:Dealer for sure.
So he can be entered in the Darwin Awards of 2011?
:twisted: :twisted:
Peter
d_generate
Post by d_generate » Fri Jul 29, 2011 4:10 am
Ask on Rexnet, I've heard of heaps of guys replacing them with 2nd hand ones on the WRX forums.
Post by Gannon » Fri Jul 29, 2011 5:57 am
An auto electrician will probably do it for you
78sti
Post by 78sti » Fri Jul 29, 2011 10:28 am
It is very simple and easy to replace with second hand ones. Just unplug and unbolt and bolt in and plug in the new one.
The airbags will not go off unless there is very dodgy wiring going on. Also the g force impact sensor should not need to be replaced unless it is crushed (mounted on the chassis rail behind the bumper)
You will know if the air bag system is not working properly as the airbag warning light will not go off when you start the car.
handsofakiller
Post by handsofakiller » Sat Aug 06, 2011 5:16 pm
i'm looking for someone who knows about airbags. i realise the risks thats why i'm asking..
d_generate wrote:Ask on Rexnet, I've heard of heaps of guys replacing them with 2nd hand ones on the WRX forums.
thanks man i'll look into it :)
and thankyou Gannon + 78sti
handsofakiller
Post by handsofakiller » Sat Aug 06, 2011 5:53 pm
78sti wrote:Also the g force impact sensor should not need to be replaced unless it is crushed (mounted on the chassis rail behind the bumper)
if i posted photos would you be able to tell if my sensors are crushed? i think they may be.
Return to “Tech Manual”
