EA82 distributor set up
watch this space
At zero (TDC) for #1 the cut mark pointed to bottom of tooth directly above big hole, move by one tooth bottom and is set for 20dBTDC for turbo
If you want ten degrees for carby maybe just halfway so lines up with top of tooth
Uploaded with ImageShack.us
You'll just make out my feeler gauge to the left, measuring gap at 25 thou
This is how dizzy looks when engine at 20dBTDC, the cam wheel one tooth off mark (but timed correctly)
