Impreza 05 GX Techmanual??/
AUSubaru Technical Manual. Collaborative Tech Manual for ALL Subarus.
kj0
Post by kj0 » Mon Apr 19, 2010 6:50 pm
Hey Guys,
First of all, Apologies if this is in the wrong section.
I have been searching for quite sometime for a Workshop Manual that covers the Impreza 05 GX AWD.
If Unable to get one, is there equivalent that supplies the same sort of info? Engine is still the EJ-20, but I would want to look at items as for PCD, Brakes, Exhaust. bit more than just the engine of course.
- Keiran.
Post by Gannon » Mon Apr 19, 2010 7:49 pm
Here is one for 2006, which should be pretty similar
pdftown.com_Impreza_2006.zip
Its a rapidshare file, and when you open it, you will need to put in this password "pdftown.com"
kj0
Post by kj0 » Mon Apr 19, 2010 8:56 pm
Ahh Cheers mate. hopefully it will be. It's been quite ridiculous to find.
On that note of Compatibility. Are the GX's quite close to the WRX of the same year? So body kit/PCD's are similar?
Post by Gannon » Tue Apr 20, 2010 6:31 am
Gx has a unique body kit, RX and WRX share the same body kit
All Subaru's have a 5x100mm PCD except for 2001 and onwards STi, the SVX and the Tribeca, which have a 5x114.3mm PCD
Post by TOONGA » Thu Apr 29, 2010 1:29 pm
there are lots of manuals here
http://ken-gilbert.com/impreza-manuals
top link is for the 06 which should be very similar to the 05
kj0
Post by kj0 » Mon May 10, 2010 12:57 pm
Cheers Guys,
I've tried to use the 06, and there's still quite a bit different, For example, the intake. The exhaust. There were some other things i can't remember what I was looking for at the time.
Is there a place I can find out What would match? Being a GX body kits won't really fit, but Certain Exhausts if I can fit a WRX or say a WRX Bonnet, What Suspension would work.
Cheers guys,.(Couldn't work out from there which Forum to chuck this in, So will continue it here)
Return to “Tech Manual”
