Impreza 05 GX Techmanual??/
Hey Guys,
First of all, Apologies if this is in the wrong section.
I have been searching for quite sometime for a Workshop Manual that covers the Impreza 05 GX AWD.
If Unable to get one, is there equivalent that supplies the same sort of info? Engine is still the EJ-20, but I would want to look at items as for PCD, Brakes, Exhaust. bit more than just the engine of course.
- Keiran.
- Keiran.
Here is one for 2006, which should be pretty similar
pdftown.com_Impreza_2006.zip
Its a rapidshare file, and when you open it, you will need to put in this password "pdftown.com"
Gx has a unique body kit, RX and WRX share the same body kit
All Subaru's have a 5x100mm PCD except for 2001 and onwards STi, the SVX and the Tribeca, which have a 5x114.3mm PCD
- TOONGA
there are lots of manuals here
http://ken-gilbert.com/impreza-manuals
top link is for the 06 which should be very similar to the 05
Cheers Guys,
I've tried to use the 06, and there's still quite a bit different, For example, the intake. The exhaust. There were some other things i can't remember what I was looking for at the time.
Is there a place I can find out What would match? Being a GX body kits won't really fit, but Certain Exhausts if I can fit a WRX or say a WRX Bonnet, What Suspension would work.
Cheers guys,.(Couldn't work out from there which Forum to chuck this in, So will continue it here)
