93 L Series Worshop Manual
AUSubaru Technical Manual. Collaborative Tech Manual for ALL Subarus.
trezize
Post by trezize » Wed Dec 02, 2009 2:01 pm
Hey Guys
Anyone suggest the best workshop Manual for 93 L Series. I'm looking for one with a good guide to changing CV joints..
Thanks.
GOD
Post by GOD » Wed Dec 02, 2009 2:10 pm
ausubaru.com is the best workshop manual I've found. Gregory's lacks detail, and the factory one is too detailed in most places.
One tip though, don't use the ausubaru search function, instead Google something like:
"l series" cv replacement site:http://www.ausubaru.com
and you'll find somtheing like this.
Dane.
tony
Post by tony » Wed Feb 24, 2010 9:08 pm
I found gregorys ok, there is nothing especially difficult except maybe replacing the stub axle thru the hub as you need a puller. I made one from a piece of water pipe and threaded rod and a couple of axle nuts.
discopotato03
Post by discopotato03 » Wed Mar 03, 2010 11:13 am
Coxy did my first one , lined the CV stub up through the hub/bearings and tapped gently and evenly around the outer face of the knuckle casting with a soft faced hammer - nylon or copper can't remember .
I did the second one without much difficulty .
Just better to use a knockometer made of softer material than the component being persuaded .
Also fitting the nut on backwards (to the full depth of its thread) is a good way to knock things out , the aim being to protect the outer face of the nut and the threads on the CV's stub axle . Again preferably with a soft faced hammer . Every good set of tools has one .
A .
Post by TOONGA » Tue Mar 09, 2010 4:43 pm
gregorys is here if you can't find anything else
http://subaru.ath.cx/Gregorys%202wd%20& ... %20Manual/
Just right click on the links and save as
Return to “Tech Manual”
