USA v UK Brumby
USA v UK Brumby
Hey Guys,
Ive got a subaru workshop manual for my Brumby which is quite usefull for the mechanical stuff. But all the specs ie plug gaps tensions refer to US or Uk dimensions, does anybody know which of these two is relative to the Oz version! Im assuming its the pommy one but i want to make sure before i do anything.
Cheers RubiSubi.
Cheers RubiSubi.
Because of different fuel quality and types available across this planet many countries had different settings. Of cause as our fuels change over the years these settings become invalid. Your pretty set if you set the plug gap to .8mm - .9mm and the timing at 10 to 12 BTC. I have a manual for Brumby's so I can find out the exact old figures on most things if you want, just ask.
As for ft-lb to Nm, just type that in google and you'll get the conversion figures you need. Like this
check this one out for conversions its got the lot
http://joshmadison.com/article/convert-for-windows
i use this one . the only thing i have found they cant convert is an old wife for a new one lol .
http://www.onlineconversion.com/
dibs
dibs
looks good has heaps more stuff
i use convert because its a download use to fit on a floppy disk (still dose but who uses them)
good for when i dont have access to the net which always happens to be when you need it
