1989 MPI EA82 distributor & rotar
Subaru had the parts imported from Japan in about a week and a half (picked them up and installed them 15/02/12) - Cost for distributor and rotor $116.10. Distributor cap part number 2216AA040, Rotor part number 22157AA001
- New Rotor.jpg (29.44 KiB) Viewed 29555 times
- EA82 Dissy_Rotor.jpg (36.84 KiB) Viewed 29559 times
I have the same engine in my Brumby and have had little luck in finding the correct cap also, purchased one from the UK only to find it was wrong. Unfortunately I don't have a VIN from the donor vehicle to go to Subaru with, so today I purchased a new distributor in the shape of a very bent 2006 Impreza wagon for its NA EJ204 and 5 speed dual range AWD trans. Let the games begin.
___________________
Lionel.
91 Brumby EA82 MPFI
09 Cobra replica 6.0l chev
Lionel.
91 Brumby EA82 MPFI
OH YER ! Let the pussy cat growl !LT65 wrote:I have the same engine in my Brumby and have had little luck in finding the correct cap also, purchased one from the UK only to find it was wrong. Unfortunately I don't have a VIN from the donor vehicle to go to Subaru with, so today I purchased a new distributor in the shape of a very bent 2006 Impreza wagon for its NA EJ204 and 5 speed dual range AWD trans. Let the games begin.
I have done a little more searching and have discovered this distributor cap no 22162AA040 also fits 6/86 to 2/89 Suzuki Swift 1.3i 16v and Nissan Terrano 2 Z241.
other manufacturers part no's Standard motor products JH180, Airtex/Wells 5D1242, QH XD297, Intermotor 45471, Suzuki 33321-641310, Lucas DDJ, Hitachi 44588-17001,Nissan 22162-17M03/4/5.
Good luck
Good luck
___________________
Lionel.
91 Brumby EA82 MPFI
Lionel.
91 Brumby EA82 MPFI
- PhilsWagon
Anybody get any further with generic options for dizzy cap and rotor?
Auto pro/supercheap/repco don't have any listings.
Subaru Australia says they don't stock them (22162AA040 - Cap & 22157AA001 - Rotor) have to be shipped from Japan and want $130ish for the pair!?!?
I've found some options on ebay in the US but am a bit cautious after the timing belt kit I ordered came with no box and with 2 damaged right hand tensioner pulleys.
Any help would be awesome!
I have 2 listings for EA82 EFI dizzy caps and rotors. Either clip on or screw on cap, also if it's Nippon or Hitachi dizzy.
Have you got any pictures of your cap?
- PhilsWagon
Just been fiddling with an optical dizzy from EA82T part number ending in AA410.
The rotor button I ran on my SeriesOne L Series mpfi EA82T Bosch GH605 measures up same when fitted - just no brass internal bushing or retainer screw to sh!t you. Looks a lot less plastic in the 605, but looks like it will do the job
The brass contact for the caps terminals is same 36mm above a point on the dizy body for both rotors
