I am after an extended steering shaft for an MY with manual steering and a 2" lift.
I have an extended shaft for a power steering rack which I am happy to swap for a manual one.
Extended steering shaft
That is good. The only issue is that I am currently using part of the power steering shaft to extend the manual steering shaft, so you would have to send it to me first and I will install it, then I can send the power steering shaft to you.
Also, I extended the slot on the flange that goes on the steering rack all the way to the end to make it clamp better. I can weld it back up if you want.
Here is a picture of what I have, does this look like the right part to you?
