2" engine crossmember lift blocks - L series
Posted: Sun Jun 22, 2014 4:20 pm
by AndrewT
Looking for a pair, thanks.
Posted: Thu Jun 26, 2014 3:35 am
by RSR 555
I have an apple.. will that do? :p
Posted: Fri Jun 27, 2014 2:31 pm
by AndrewT
I may be a Dad now, but even I won't pay that joke!
Posted: Fri Jun 27, 2014 5:39 pm
Why not make them yourself? A bit of 50mmx40mmx3mm (or 4mm if you want) with some crush tube welded in would be ample...
I'm sure you know how to measure twice and cut once, then the same for the two holes required and do the welding - I've seen some of your work and this to me should be a piece of cake for you.
Posted: Fri Jun 27, 2014 7:06 pm
by AndrewT
yes it would be, but I am building this car literally 15 minutes at a time, whenever I can squeeze off a spare moment. I barely have time to go to the shops to buy more welding wire. If someone has some blocks I'll grab them. As it happens, Paul has some for me.
